Exhaust Size Question?
Old Feb 17, 2004 | 11:27 PM
TurismoVette's Avatar
TurismoVette
Default Exhaust Size Question?
I was looking through MAD's website and noticed on the Borla exhaust sytems that the 2 1/2" exhaust has half the horse power of the 3" system. I am looking to get either the KBD mufflers or muffler eliminators. Should I get the 3 in or will the size not make a difference with just mufflers or elim.? I do not have any mods on the car if it would make a difference.... Thanks
http://www.madvet.com/shop?frame=3.119.992 KBD
http://www.madvet.com/shop?frame=3.119.987 Eliminators
Old Feb 17, 2004 | 11:43 PM
88_vette's Avatar
88_vette
Default Re: Exhaust Size Question? (TurismoVette)
Stock car I think either one will make a difference over stock mufflers. I will warn you though. You are most likely to pickup some res. around the 1300-1700RPM range. May not but don't be shocked if you do.
Old Feb 18, 2004 | 03:09 PM
speedjohnson's Avatar
speedjohnson
Default Re: Exhaust Size Question? (88_vette)
The three inch system is just unnessisarily louder on a stock vehicle.
Old Feb 18, 2004 | 03:32 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
For an LT1 with essentially dual exhausts the 2 1/2" system will be fine to about 400chp.
For an L98 with Y pipes I would use 2 1/2" for separate pipes into/from 3" at the Y.
Old Feb 18, 2004 | 09:09 PM
h rocks's Avatar
h rocks
I don't understand what "the Borla exhaust sytems that the 2 1/2" exhaust has half the horse power of the 3" system" means. :confused:
Even if you have a built motor, there's not much chance that you will need anything larger than a 2.5" setup. Corsa did a dyno comparison on a stroked ZR1 with both a 3" and a 2.5" system. (both were Corsa setups) That car made more HP and TQ with their 2.5" system. Bigger is not always better as we have found in cams and heads.
Old Feb 18, 2004 | 09:21 PM
TurismoVette
Default Re: Exhaust Size Question? (h rocks)
I saw it in the Ecklers catalog. It was the B&B Tri-Flow Perf Exhaust. This is a direct quote from the catalog.
Note: 2 1/2" systems are available in lieu of the 3" systems at a lower cost, however, sound quality is the same, but horspower is half that of the 3" systems.
So I guess it is just there systems and not any others. :confused:
Old Feb 18, 2004 | 10:37 PM
Perfusion's Avatar
Perfusion
Guys that have LT4s (stock exhaust size: 2 3/4") run Corsas (2 1/2") left and right and get dyno proven gains. As previously stated, 2 1/2" can flow *more* than enough for most motors. It's all about the mufflers (or "resonators").
To Exhaust Size Question?
