New spring pre-load?
Old Feb 18, 2004 | 09:54 PM
96BLKTN's Avatar
96BLKTN
Default New spring pre-load?
I just got all of the parts for my 1.6RR's. I read an article in Corvette Fever about pre-loading the springs before install so you can get the correct heght and not have to re-shim. Anyone done this? :smash:
Old Feb 18, 2004 | 11:52 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: New spring pre-load? (96BLKTN)
If I were building a new motor I would do so, But with over 100,000 miles on mine before switching to 1.6 rollers and LT4 springs, I just went with the recommended installed height. For my purpose, a couple of pounds here or there, ain't going to make much of a difference. :jester
:cheers:
Old Feb 20, 2004 | 06:19 PM
96BLKTN's Avatar
96BLKTN
Default Re: New spring pre-load? (AGENT 86)
Well I did it I say can't hurt. They are going on tomorrow. Can't wait, then I guess I'll have to decide what is next on the list. :cheers:
Old Feb 23, 2004 | 09:05 AM
JAKE's Avatar
JAKE
This is trick that has been around for a long time.
Take each new spring and compress it in a vice several times to coil bind. This allows the spring to take a set. Then install them at the correct seat pressure and that setting will remain much more constant.
Be sure to protect the spring from the jaws of the vice.
New springs lose seat pressure when not pre-stressed which then calls for shimming to bring them back into spec.
Jake
To New spring pre-load?
