EM Header Question
Old Feb 19, 2004 | 02:33 AM
STL94LT1's Avatar
STL94LT1
Default EM Header Question
I recieved my EM headers today, and I'm really impressed with their quality. Only one problem, my air tube fittings are not drilled through the header tubes. Is anyone elses predrilled, or are we suppose to drill as needed?
Old Feb 19, 2004 | 06:20 AM
FX GS's Avatar
FX GS
Default Re: EM Header Question (STL94LT1)
You drill as needed
Old Feb 19, 2004 | 07:31 AM
RichS's Avatar
RichS
Default Re: EM Header Question (FX GS)
I'm hoping the set we ordered for my buddy's 96 CE comes this week :cheers:
Old Feb 19, 2004 | 09:28 AM
NavyVet's Avatar
NavyVet
EM Headers :yesnod:
Old Feb 19, 2004 | 09:34 AM
C4Crazy787's Avatar
C4Crazy787
I talked to Merle about that last week, he said they don't drill'm incase someone was not going to reinstall the AIR system. I'm keeping mine so he said a 3/8 hole should do the trick. :seeya
Old Feb 19, 2004 | 11:00 AM
STL94LT1's Avatar
STL94LT1
Thanks guys.
Going to do a test fitting this weekend, can't wait to hear the car run with the new headers/high flow cats.
Old Feb 19, 2004 | 11:01 AM
cprgmr's Avatar
cprgmr
Default Re: EM Header Question (C4Crazy787)
I have the same issue - to keep the AIR and drill or ditch it. So, are there any advantages to eliminating the AIR system? Does anyone know what's involved beyond the obvious (blocking off the AIR pipe connector at the back of the intake)?
Old Feb 20, 2004 | 08:15 AM
96GS#007's Avatar
96GS#007
Default Re: EM Header Question (cprgmr)
If you're going to run catalytic converters (i.e. Random Tech bullet cats, etc), you want to keep the AIR system.
Old Feb 20, 2004 | 09:32 AM
cprgmr's Avatar
cprgmr
Default Re: EM Header Question (96GS#007)
Thanks Jim - I'm going with EM long tubes so the cats will be gone! :cheers: I guess then it would be possible just to block off the plate, etc...
Old Feb 20, 2004 | 09:37 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Pull the tubes, block off the plates, and get a custom chip with it outta there.
:yesnod:
To EM Header Question
