Replacing a CAM
Feb 19, 2004 | 02:03 PM
Cruising
Replacing a CAM
How difficult of a job is it to replace the CAM? I am being told that my #2 cylinder is getting too much fuel and could be a CAM problem.... Am considering doing this myself... Anybody else done one on their own? :rolleyes:
Feb 19, 2004 | 03:15 PM
Re: Replacing a CAM (tiedt)
Just lots of time and patience and a Haynes or other manual. It took me about 22 hours on my '86.
Feb 19, 2004 | 04:27 PM
Just takes a good bit of time and unbolting alot of things, as well as replacing a good many gaskets.
How can a fueling problem in one cylinder be cam related, it would make more sense if it were an injector problem.
Feb 19, 2004 | 05:27 PM
Re: Replacing a CAM (shotchkiss)
SOUNDS LIKE A FUEL INJECTOR PROBLEM. :flag
Feb 19, 2004 | 07:51 PM
Your cam is NOT causing your #2 to run fat.
Feb 19, 2004 | 08:52 PM
Re: Replacing a CAM (Admiral)
:iagree:
The Cam is not too hard as long as you are mechanically inclined somewhat. But I doubt it is the source of your problem.
Feb 19, 2004 | 08:55 PM
:iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree:
Feb 20, 2004 | 01:02 AM
Re: Replacing a CAM (TreyZ28)
Dang Trey, fall asleep on that :iagree: button. :lolg:
Feb 20, 2004 | 01:22 AM
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Hey Trey, I'm gonna go out on a limb here and guess that you agree........ :lol:
Feb 21, 2004 | 09:09 AM
Cruising
I still have to check all the other fuel injectors, but the injector on #2 had 16 ohms on it. Just from what I have read before, that seems to be within a good range....Like I said though, I still need to check the others to see if it is within the same range. If the Ohms are all good, I would think it would be a bad cam? Any other ways I can diagnose the problem..... :jester
Feb 21, 2004 | 09:35 AM
The injector could be dirty and causing it to stick open.
Feb 21, 2004 | 09:59 AM
St. Jude Donor '11
So Trey, are you saying that you dont think its a cam prob? :jester :lolg:
jeff
Feb 21, 2004 | 01:39 PM
Re: Replacing a CAM (GS345)
Put a dial indicator on the #2 intake and exhaust valve spring retainers then do the same thing with two others. Bump the engine over and make a note of max valve lift.
Compare the lift readings you get. If the #2 lobe(s) are worn it'll show up in the valve lift readings.
Remember to compare intake with intake and exhaust with exhaust.
Jake
