C5 wheels on C4
Old Feb 19, 2004 | 04:49 PM
87 covertible's Avatar
87 covertible
Default C5 wheels on C4
Anybody else running Y2K or Z06 wheels on a C4 ? Would like to see some pics if you have them ! :auto: :steering:
Old Feb 19, 2004 | 07:08 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: C5 wheels on C4 (87 covertible)
:cheers: there should be a lot of pics along shortly :D I have them on my 88 vert and love them, they are a lot easier to clean than my old wheels
You will probably need to run spacers/adapters to fit them properly :rolleyes:
They bolt right up to 88 and up because of the suspension changes in 88
You can probably get the best deal on these wheels right here on the Forum in the C5 parts for sale section
:seeya
:steering:
Old Feb 19, 2004 | 09:34 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
See sig :D
Old Feb 19, 2004 | 09:59 PM
Preacher's Avatar
Preacher
Default Re: C5 wheels on C4 (_freakmonkeydogboy_)
:thumbs: 18" rear, 17" fron, powdercoated Y2K's on my 1995, direct bolt on, no spacers, no problems.
Old Feb 19, 2004 | 10:52 PM
vms4evr's Avatar
vms4evr
Default Re: C5 wheels on C4 (Preacher)
I did like Preacher. I have 99 wheels so the spokes are a little thicker. Black powder coated. Instead of using the 17/18 combo I have all 4 in 18x9.5. 245/40-18 front and 285/35-18 rear. No problems at all. This is on a Red 92.
If Preacher had the same problem I did then I can assure his wheels look even better in person than the image shows. Both my digital camera and my daughters 35mm did not like the combo :( The wheels and tires blend together too much in my pictures and you loose the detil that you can see in person. I have some silver/grey center sections and my old 92 lug nut covers freshly painted in silver. I also cleaned up my calipers and painted them and the hubs of the rotors because they were nasty and are now very visible.
They make the C4 look significantly different than it did with the sawblades. Not that there is anything wrong with sawblades. The 5 spokes are definetely easier to clean.
Graham
[Modified by vms4evr, 10:53 PM 2/19/2004]
[Modified by vms4evr, 8:01 PM 2/20/2004]
Old Feb 20, 2004 | 12:43 AM
BAM92's Avatar
BAM92
Default Re: C5 wheels on C4 (vms4evr)
On your 87, you will have to buy spacers for factory wheels or buy aftermarket ones with correct offset. They really look great on C4's. :thumbs:
Old Feb 20, 2004 | 02:10 AM
lb33knight's Avatar
lb33knight
Default Re: C5 wheels on C4 (jackdaroofer)
:iagree: They are much easier to clean. See my sig. :seeya
Old Feb 20, 2004 | 05:59 AM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Default Re: C5 wheels on C4 (lb33knight)
Check my sig....
Old Feb 20, 2004 | 09:04 AM
QuikZilver's Avatar
QuikZilver
18" Chrome Z06's...see sig.
:cheers:
Old Feb 20, 2004 | 11:04 AM
corvettemaster's Avatar
corvettemaster
i think all the c5 wheels look great on a c4. and you can get a set rather cheap. you guys who powdercoated yours, the look really good :thumbs:
Old Feb 20, 2004 | 11:22 AM
comp94's Avatar
comp94
Default Re: C5 wheels on C4 (corvettemaster)
see my sig
[Modified by comp94, 4:25 PM 2/20/2004]
Old Feb 20, 2004 | 11:34 AM
4-ACES's Avatar
4-ACES
From: Northern KY.... Just 3 hours to Las Vegas in a 767
17x9.5 and 18x10 Y@K's on 275/315 Pilots....See sig
:cool:
To C5 wheels on C4
