JET low temp cooling fan switch..which coolant temp sensor to replace
Old Feb 20, 2004 | 11:30 AM
brock71's Avatar
brock71
Default JET low temp cooling fan switch..which coolant temp sensor to replace
Someone on another board thought that the switch I need to remove is on the drivers side of the motor. I looked in the manual and there is a coolant temp sender there. But in the service manuals it says the switch for the fans is on the pass side by the dipstick tube.
Old Feb 20, 2004 | 01:00 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: JET low temp cooling fan switch..which coolant temp sensor to replace (brock71)
GM swapped the location of the temperature guage sending unit with the fan switch, several times. Go with your manual. If you'll give us the YEAR of your car, I may be able to confirm the location with my parts book.
RACE ON!!!
Old Feb 20, 2004 | 01:07 PM
scorp508's Avatar
scorp508
88 will have the fan switch between cylinders #1 & #3.
p.s.
To identify.
Coolant Temp Sendor for Cluster is a 1 pring flat blade connector.
Fan Swtich is a push on round single wire connector.
[Modified by scorp508, 1:08 PM 2/20/2004]
Old Feb 20, 2004 | 01:38 PM
brock71's Avatar
brock71
Default Re: (scorp508)
It is an 88. That's what the connector on this temp swich looks like. Round.
Odd though that the 88 service manual says it's by the dip stick...but hey you guys probably know the cars better than I do at this point.
Old Feb 20, 2004 | 01:54 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: (brock71)
My parts book, for what it's worth, confirms scorp's info for a 1988.
RACE ON!!!
Old Feb 20, 2004 | 08:54 PM
427 Big Block's Avatar
427 Big Block
Cruising
Default Re: Cannot remove head plug
Gentleman. I just purchased the Jet fan kit for my 94' and cannot remove the plug from the drivers head between plugs 1 and 3... Any suggestions? I heated the surronding area, used a .5" impact, large breaker bar and am losing my patience. There are no other plugs on the engine.
Comments?
Old Feb 20, 2004 | 10:06 PM
brock71's Avatar
brock71
Default Re: Cannot remove head plug (427 Big Block)
PB Blaster. Stuff works like magic. Shoot some on there let it sit for an hour try to pull it. Repeat if it's still stuck.
Old Feb 20, 2004 | 10:49 PM
427 Big Block
Cruising
Default Re: Cannot remove head plug (brock71)
Thanks for the reply, where do I find this stuff? I will give it a try.
Pete
Old Feb 20, 2004 | 11:56 PM
JCAIRE2's Avatar
JCAIRE2
Comments?
Heat the plug, and spray it with some wd40 while it's hot. Should come right out.
Old Feb 21, 2004 | 02:19 AM
Stingraynut's Avatar
Stingraynut
Default Re: Cannot remove head plug (JCAIRE2)
NO - the sensor between #1 and #3 on my 88 doesn't turn the main cooling fan on, it turns on the other optional fan that is in front of the radiator .
Easy way to tell is to discoonect the plug from the sensor, turn on ignition and ground the plug to the engine and see which fan runs.
From my research I found that the ECM turns on the main fan at a set temp (way too high I reckon), getting info from another sensor at the front.
Hope this helps
S'nut
Old Feb 21, 2004 | 06:53 AM
86PACER's Avatar
86PACER
p.s.
To identify.
:iagree:
Guys with only 1 fan have a pipe plug instead of a temp switch between the #1 and #3 spark plug threaded on the cylinder head. I had to grind down a pipe plug socket to an 8mm size to fit the square hole in the plug to remove it.
Guys with 2 fans simply remove your old switch and install the new one.
Old Feb 21, 2004 | 10:54 AM
brock71's Avatar
brock71
Default Re: (86PACER)
Well there is a switch between the #1 and #3 cylinders...so I suppose that's it. There is also a switch by the dipstick. Really makes me wonder why they needed so many GD coolant temperature sensors...there has to be at least 4.
PB Blaster can be bought at any autoparts chain. I use Autozone.
[Modified by brock71, 3:54 PM 2/21/2004]
Old Feb 21, 2004 | 01:13 PM
CFI-EFI's Avatar
CFI-EFI
The item next to the dipstick on your '88 is the temperature guage sending unit, not a switch. Remember my initial post?
In addition, you have a temp sending unit in the front of your intake manifold, for the ECM, and an IAT, if your car is so equiped. There is also an oil temp sensor above the oil filter in the block. I THINK that is the end of the temp sensors. As I'm sure you know, the ECM controls the main fan. The temp switch controls the aux fan.
RACE ON!!!
To JET low temp cooling fan switch..which coolant temp sensor to replace
