Disconnected Battery-readings are not right?
Old Feb 20, 2004 | 07:54 PM
David C.'s Avatar
David C.
Default Disconnected Battery-readings are not right?
I have a 95 conv.,I disconnected battery,now my fuel reading (range) is not accurate.I was told to reset fuel and i did,didnt correct.I was told to drive it awile it may go back to normal,didnt correct.I filled tank up today and it reads 265 miles to empty,when it use to say 355 ,miles to empty.Im not sure if my other digatal reading are correct (coolant,oil,volt etc.) because i normally just look at my needle reading.Can someone help me with this.
Old Feb 20, 2004 | 08:33 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Disconnected Battery-readings are not right? (David C.)
I think we pretty much answered that for you, here:
http://forums.corvetteforum.com/zerothread?id=755879
You're going to have to drive it through a cycle or two for the computer to re-learn, what is "normal".
RACE ON!!!
Old Feb 20, 2004 | 09:20 PM
greenvette95's Avatar
greenvette95
St. Jude Donor '03
Default Re: Disconnected Battery-readings are not right? (CFI-EFI)
:iagree: :flag
Old Feb 20, 2004 | 10:29 PM
David C.'s Avatar
David C.
I didnt realize I had to drive it a few cycles first,I assumed after I drove it awile and refilled, I would be o.k,I will drive it more and take your advise,Thank you.
To Disconnected Battery-readings are not right?
