Wiper woes
Old Feb 20, 2004 | 09:43 PM
AEmedic's Avatar
AEmedic
Default Wiper woes
I have no wiper related function at all...
No wipers at any speed, no washers, nothing works at all.
The other functions of the multifunction switch work so I am not certain it is bad.
The wiper motor cover is cracked, looks like it was hit when the engine was swapped, so the circuit board could be bad. If it were bad would that stop all functions I am referring to? What is the proper name for the cover with the board?
I was reading in the archives and I saw a few people had found this cover locally but no one knows what I am talking to at Napa, schmucks, etc...
Any and all help would be appreciated.
Old Feb 20, 2004 | 09:56 PM
Pete K's Avatar
Pete K
Default Re: Wiper woes (AEmedic)
I had same problem. I cracked mine with super-ram during a trans swap. 2 years later wipers quit. I changed the cracked cover first. I figured I had nothing to lose . The damn thing was like $90!!! Good luck! :cheers:
Old Feb 20, 2004 | 10:08 PM
AEmedic's Avatar
AEmedic
Default Re: Wiper woes (Pete K)
Where did you find the cover?
Old Feb 20, 2004 | 10:17 PM
Pete K's Avatar
Pete K
We have a local ac-delco master distributor -Rymer Auto Electric- Otherwise GM stealer should have it. I called the corvette junk yards and they wanted $100 for a used one. (It was motor and cover though) :eek:
To Wiper woes
