L98Pushrod?
Old Feb 22, 2004 | 05:52 PM
redfast's Avatar
redfast
Default L98Pushrod?
About to buy some edelbrock perf. rpm alluminum heads for my 85 and was wondering what size pushrods I need. Will the stock length work good? The cam I was going to go with is about .490" lift. Any one have a simular set up, any opinions and/or answers would be greet.
Old Feb 22, 2004 | 05:59 PM
Black87c4's Avatar
Black87c4
Default Re: L98Pushrod? (redfast)
Get an adjustable pushrod, that way you'll know exactly what length to get. I believe there are more factors involved than just knowing what cam. What type rockers, stock stamped won't use the same length as full rollers, etc.
Old Feb 22, 2004 | 06:15 PM
redfast's Avatar
redfast
Default Re: L98Pushrod? (Black87c4)
Ya thanks i just wanted to see if anyone had a simular setup, yes im getting the pushrod checking tool. Thanks
Old Feb 22, 2004 | 06:37 PM
JAKE's Avatar
JAKE
I'm running those heads, 60739, and I had to go with aftermarket pushrods. If I remember correctly, Edelbrock says you need +.100 if you're running stock rockers.
Best to use a pushrod length checker to see exactly what you need.
Jake
To L98Pushrod?
