Superram with Fast burn heads?
Old Feb 23, 2004 | 02:38 PM
ZAD54's Avatar
ZAD54
Default Superram with Fast burn heads?
GM Performance now has a motor called ZZ383/425. And as you can guess its a 383 with 425 hp. My question is, since it comes with fast burn head, do they make a SR for use with FB heads or will I have to look for another intake if I decide to get this crate motor. Heres a link: http://www.gmpartsdepot.com/store/pr...roduct_ID=1756
Old Feb 23, 2004 | 02:59 PM
Raistlin's Avatar
Raistlin
Default Re: Superram with Fast burn heads? (ZAD54)
you'll need to go w/ a special lower intake to mate w/ the fast burn heads http://www.sdpc2000.com/cart.asp?act...1460&pid=13740
Old Feb 23, 2004 | 04:27 PM
ZAD54's Avatar
ZAD54
Default Re: Superram with Fast burn heads? (Raistlin)
So the vortec lower will mate up to the SR upper without any problems???? I would hate to get into fitment problems while installing it. :confused:
Old Feb 23, 2004 | 04:47 PM
Raistlin's Avatar
Raistlin
Yes, but if you're looking for no fitment problems, the super ram may not be to your liking. I've never installed one, but it seems that many on this forum dread removing/installing the SR.
A serach for super ram install should bring up a few posts. scorp has some excellent suggestions on making the install as painless as possible.
Hopefully someone who's done this combo will chime in.
Old Feb 23, 2004 | 06:42 PM
FD2BLK's Avatar
FD2BLK
An alternative would be to get a single plane from jeb.
[Modified by 84LT1, 5:45 PM 2/23/2004]
Old Feb 23, 2004 | 07:13 PM
RonRed89's Avatar
RonRed89
In this month's Corvette Fever, they discuss a new cast iron head from GM that would allow you to use both Gen 1 and Vortech intakes. The article is on pg 37. The Part numbers for these heads are 25534351 (165cc/64cc) and 25534371 (206cc/77cc). I'm not sure if these are the heads on that new ZZ383, but maybe with these heads, you could use the matching SR intake base instead of the Scoggin Dickey one.
Good luck,
Ron
Old Feb 23, 2004 | 07:37 PM
ZAD54's Avatar
ZAD54
Default Re: Superram with Fast burn heads? (RonRed89)
Good luck,
Ron[/QUOTE]
Yeah, Corvette Fever is where I saw the engine first. I was just wondering if they offered the SR in a FB head configuration, it sure would make it alot easier. Anyway, thanks for the reply :cheers:
Old Feb 23, 2004 | 11:35 PM
RonRed89's Avatar
RonRed89
No problem. :cheers:
Ron
To Superram with Fast burn heads?
