Tricks for replacing Speedo Gears
Old Feb 24, 2004 | 01:49 PM
Flame Red's Avatar
Flame Red
Default Tricks for replacing Speedo Gears
Folks,
It has been one thing after another, so I am looking for any short cuts that folks might have to suggest for me.
After have a rebuilt tranny installed by a supporting vendor, they must have misinstalled the speedo gears so it mangled them bad. I have new ones from Iklers on the way. I have done this before when I replaced the rear end, but I had just about everything off the car so it was no big deal. Now I dread doing it the normal way:
1. Drop the cross brace
2. Drop the exhaust
3. Disconnect the drive shft
4. Remove the C-beam
5. Remove the tranny tail assembly
6. install new gears
Any ways to cut any steps on a 90?
Should I replace the speed sensor? Not sure if they screwed that up too.
Old Feb 24, 2004 | 02:31 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Tricks for replacing Speedo Gears (Flame Red)
YES ! Have the installer step up to the plate and make good on his mistake.
RACE ON!!!
Old Feb 24, 2004 | 03:45 PM
jerkyboy's Avatar
jerkyboy
I am doing this as we speak on my '89. There is no other way that I can see to do it. Don't forget to take off the center console cover, remove the four "acorn" screws holding the shifter plate. You will need to lean the engine/tranny down to get to the top bolts of the tailhousing. I had to pull off the plastic driven gear off the shaft and install a new metal gear (had to torch it for 10 minutes to work it onto the shaft :banghead: . I am putting everything back together tonight.
Old Feb 24, 2004 | 03:51 PM
Flame Red's Avatar
Flame Red
Default Re: Tricks for replacing Speedo Gears (jerkyboy)
Were did you get a metal gear?
That looks like the way to go. Changing the plastic gear on the speedo sesnor is a peice of cake. I would love to put a metal gear on there with the right number of teath for 3.73 gears.
Old Feb 24, 2004 | 04:56 PM
jerkyboy's Avatar
jerkyboy
I responded to your IM but I'll answer here too. The cone gear inside the VSS is still plastic. Since I went with 4.11s, the plastic gear on the tailshaft was replaced with metal. I was going to go with 3.73s before and would only have needed to change out the plastic cone gear in the VSS and not touch the one on the tailshaft.
To Tricks for replacing Speedo Gears
