Interesting TPI Flow Numbers
http://www.stealthram.com/flowcomparison.html
http://dtcc.cz28.com/flow/
Jake
[Modified by JAKE, 6:53 AM 2/23/2004]
[Modified by JAKE, 6:55 AM 2/23/2004]
1. If you have a TPI MAF sensor (Stock TPI Bosch MAF sensor w/o screens -- 658.4 cfm) is there no need to ever use (NA application) a larger Throttle Body (48mm tpi = 783.0 cfm),?
2. Whole lot of flow #'s for various intakes and the stealth but 0, zip, zilch "I ran x.xx and dynoed xxx before the stealthram and improved to x.xx and xxx after installing it.
For example, in my personal experience, a stock TPI intake seems to benefit from a 52mm throttle body whereas a stock LT1 did not respond at all to the bigger TB. Of course, every engine/application is different and many other factors contribute to how your engine is going to respond to a particular "upgrade". By far, the best way of determining whether or not a certain upgrade or mod will benefit your particular application is either by trail or error, or relying on third party dyno testing using a similar engine. Keep in mind that these aftermarket companies are in the business of making money and upselling parts. One way they do this is by making their products more appealing by manipulating statistics or variables in the tests they perform; therefore, giving you the illusion that their product will give you XX horsepower gain over stock. This, more often than not, is not the case. After all, would you spend $500 on a part that would only provide you with a 5hp gain?
1987 Pontiac GTA 5.7L Superram 4L60-E (13.1et @ 109mph)
1987 Pontiac Fiero 3800 Series II Turbocharged (12.79et @ 106.6mph)
[Modified by SubZero350, 6:38 AM 2/24/2004]
[Modified by SubZero350, 6:42 AM 2/24/2004]
Nope.
I'll post the link to the site if you guys offer to buy one for me.
Jake
[Modified by JAKE, 3:02 PM 2/24/2004]
Unless the process also makes them larger, and I don't think it does, I still don't think the extruded Accels have a larger runner diameter or would out flow the ASM/TPIS runners.
Great post, good to see independent verification of claims made by companies looking to sell things, and in this case being right on the money.
