Replacing Driver's Door Glass....
Old Feb 24, 2004 | 03:47 PM
steelwindmachine's Avatar
steelwindmachine
Default Replacing Driver's Door Glass....
I haven't yet taken the door panels off and started this project, but according to my shop manual I need a special socket tool in order to remove the nuts that go on the studs that hold the glass to the regulator.
Does anyone have a comparable tool for this or means to get this done?
thanks,
Old Feb 24, 2004 | 03:57 PM
sraft's Avatar
sraft
Default Re: Replacing Driver's Door Glass.... (steelwindmachine)
:lurk:
need to do this also - I'll be watching the responses.
Old Feb 24, 2004 | 04:13 PM
JasonL's Avatar
JasonL
Special socket? Been a while but I sure don't remember using any special tools....
Old Feb 24, 2004 | 04:20 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
No you don't need a special tool. I think I used a pair of needle nose pliers. If memory serves me correctly???
Old Feb 24, 2004 | 06:57 PM
Sam Lam's Avatar
Sam Lam
Default Re: Replacing Driver's Door Glass.... (edsalinas)
I think "the tool" is going to a minor problem as you look back on the experience. The major "big problem" will be to adjust the glass where you do not have the pesky, wind noise. I have been trying to get a quiet ride in my 89 for some time and have not found the correct technique. I would like to see a glass adjustment procedure.....and you will too! OMG...400 posts and this car is addictive!!! :lol:
[Modified by Sam Lam, 5:59 PM 2/24/2004]
Old Feb 24, 2004 | 07:39 PM
edsalinas's Avatar
edsalinas
Default Re: Replacing Driver's Door Glass.... (Sam Lam)
[QUOTE].........OMG...400 posts and this car is addictive!!! :lol:QUOTE]
It's only just begining bro...........
Old Feb 25, 2004 | 02:18 AM
VenkmanP's Avatar
VenkmanP
One side of mine was tight enough to need no tool (to hold the stud while turning the nut.)
The other side I was able to get with right-angle needle-nose pliers.
Old Feb 25, 2004 | 02:56 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Guys, I have a window procedure from another forum member... email me and i'll send it out... It works.... :thumbs:
Old Feb 25, 2004 | 05:36 AM
LD85's Avatar
LD85
Default Re: Replacing Driver's Door Glass.... (vinnies87)
No special tool when I replaced my 85 Drivers side window :thumbs:
Old Feb 25, 2004 | 01:17 PM
ABNVET.I's Avatar
ABNVET.I
Default Re: Replacing Driver's Door Glass.... (ld85)
:iagree:
Yep I just used a set of right angled needle nose. There is a disk there with 2 holes in it that spins off like a nut. So the needle nose fits right in the holes and it comes off pretty easy.
Old Feb 25, 2004 | 01:33 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
Default Re: Replacing Driver's Door Glass.... (1hot90)
My 86 had 10mm nuts holding it on ...piece of cake... adjustment was trail and error but pretty painless... I have three more of these to do and hopefully I'll feel the same way afterwards :auto:
Old Feb 25, 2004 | 07:23 PM
Glasman66's Avatar
Glasman66
The tool they are talking about is called a spanner wrench. It is for the spanner nuts.
In my 12 years of replacing auto glass I have never used one, I always went the route of the needle nosed pliers.
I had a bitch of a time trying to get the guide on the front of the glass off. The 10mm nut just spun. I ended up ducttaping the glass and breaking it to get it out. After 12 years in the business all it took was a Vette to make me humble again. These can be a pain to adjust. :sad:
Old Feb 25, 2004 | 07:38 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Replacing Driver's Door Glass.... (Glasman66)
:iagree:
These look just like the wrenches used to remove grinding wheels from your die-grinder.
They have two pegs sticking out sideways, spaced a certain distance apart that go into the holes in the window stud's base.
[Modified by CentralCoaster, 4:38 PM 2/25/2004]
Old Mar 2, 2004 | 12:02 AM
Glasman66's Avatar
Glasman66
Default Re: Replacing Driver's Door Glass.... (CentralCoaster)
:iagree:
That's the spanner socket alright.
To Replacing Driver's Door Glass....
