Interior light problem!!!!
Old Feb 25, 2004 | 08:43 AM
1992B4C's Avatar
1992B4C
Default Interior light problem!!!!
Here is a problem I hope someone has experienced before. The switches on my dash and console do not light up when the interior lights are on. The dash lights gauges light up just fine and the heater LCD lights up, but none of the back-lit buttons light up. I checked every fuse and none of them are bad.
Anyone know how to fix this or what to look for???????
:confused: :confused:
Old Feb 25, 2004 | 10:08 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Interior light problem!!!! (1992B4C)
I'll take a look at my helms and see if i can find anything...
Old Feb 25, 2004 | 09:50 PM
korvette4u's Avatar
korvette4u
Default Re: Interior light problem!!!! (vinnies87)
:lurk:
I have similiar problem......waiting :)
Old Feb 25, 2004 | 09:52 PM
Batvetteman's Avatar
Batvetteman
I have this very same problem. Gauges light up fine but no heat/ac controls are visable at night. Someone correct me if I'm wrong but on my 1990, I think the buttons are not back-lit but are illuminated by a small bulb that shines down on them from the rear view mirror. I replaced this bulb with a new one and all fuses are good but still it doesn't work. :confused:
Old Feb 25, 2004 | 10:35 PM
rick lambert's Avatar
rick lambert
Default Re: Interior light problem!!!! (Batvetteman)
Have you guys checked your grounds yet? I believe there are three, two are on the engine block on the back side (firewall side) I forget where the third is,
I believe from the dash to the pillar on drivers side. Hope this helps. :rolleyes:
Old Feb 25, 2004 | 10:42 PM
Curveit's Avatar
Curveit
It may not be the same on your later model, but the Heat/AC control on my '86 did this not long ago. The lights went out, and the temp numbers would occationally go beserk. Before I did anything drastic, I took the control unit out and cleaned all the contacts; fixed the problem. Another time some of the other dash lights went out and it was a fuse. Hope this helps.
:chevy
Old Feb 26, 2004 | 07:37 PM
Batvetteman
Default Re: Interior light problem!!!! (Curveit)
:chevy
Whats the "control unit" and how do you remove it to clean the contacts?
To Interior light problem!!!!
