I just took off my Plenum to strat porting it and I have gas in it,,,, not alot but some,,,, what is this caused from and is it normal??????????? :eek:
Re: Gas in Plenum???????????HELP<<<SOS (1990CORVETTE)
:eek: Are 100% sure it's gas?
That sounds kind of impossible b/c the injectors are in the manifold base and even if they were to spray w/ the valve closed, the runners are very long and it'd be hard for fuel to reach all the way up to the plenum.
The only place raw gas can come from is the charcoal canister or something that has to do with it - sounds like yours may be done for - I'd remove it and see if there's gas in it, particularly if your Vette has a lot of miles.
Re: Gas in Plenum???????????HELP<<<SOS (War Machine)
Not impossible. I posted a few months back that I ran across a lady with an 87 with gas pouring our of her throttle body....I mean a lot of gas. It was leaking from the air cleaner box too.....
