88-C4-5.7
Ok, we all have problems getting the coolant system full because air is trapped in the block somewhere. I have a tool that pulls a vaccum on the coolant system then sucks the coolant into the system eliminating air trap. This has worked for me on every single vehicle except my corvette. I still get a low coolant signal until I drive and fill for a while, maybe days. I usually do the 2000 rpm thing while topping off but still get the low light for a while. I'm thinking an air bleed somewhere in the intake, or maybe topping off on a steep incline. Any Takers??? :thumbs:
Is the light on as soon as your turn the key ?
If so, don't start, but open your rad cap and verify that coolant is actually lower than sensor.
Just a thought, maybe bad sensor or loose connection.
:cheers:
Usually the 2000 rpm top-off does a good job. Is the engine warmed up with the stat open when you're doing this? Another little trick, is to raise the front end with tall ramps or a jack until the radiator cap becomes becomes the "high point" in the cooling system. Of course the heater is on while you're topping off. Good luck, and...
... but? why would the heater need to be on?
:confused:
Automotives 101: Cooling system Basics.
The same water that passes through the engine and radiator, also goes through the heater core. That is where the heat comes from when you turn the heater on. Have you ever noticed that the heater doesn't put out any heat until the engine warms up? The heater core is a heat exchanger, a smaller version of your radiator. You want the heater to be on so the coolant is circuating through the heater core. If there is air trapped in the heater core, there is air trapped in the cooling system.
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Coolant Top-Off Topic... (JAKE)
:cheers: I believe that coolant continuously circulates through the heater core on the L 98, so turning the heater on is of little consequence
The hole drilled (1/32) in the thermostat deck, along with the other procedures mentioned, should do the trick.
I am fortunate to have a Kwiklift and I always lower the rear end before filling the system. The air (IMHO) get's trapped in the upper radiator hose since that is the highest poiny in the system
I haven't looked for the valve, but on my 91, when the temp is set to hot (fan off), the surrounding dash gets hot. Set to cool, stays cool. This would lead me to believe there is a coolant control valve. Anyway, it's good practice to have the temp control set to full hot when filling the radiator.
What if you just fill up the radiator, then drive arround for a few days and then fill it up some more, then drive arroudn for a few more days and then fill it up some more.
Would this eliminate the magority of the air pokets or bubles?
Because that all I did with my car and the engine temp is normal "never went over 230 with stock termostat" and I have no problem with the low coolant light.
[Modified by TheStef, 7:49 AM 2/27/2004]
The only way I know of that will allow the air to escape from the system is if the radiator cap opens due to the excessive pressure and vents the air vents to the overflow bottle (can't spell "resevoir" , lol). Otherwise, it's trapped in the system.
Then as the engine cools, a suction is created and coolant is drawn back into the radiator from the over-flow gizmo.
I think his rationale is that after driving for a while, all the bubbles will get collected in one spot, not that they will escape from the system by themselves.
