L98 MAF Sensor Testing?
Old Feb 26, 2004 | 12:02 PM
geezel's Avatar
geezel
Default L98 MAF Sensor Testing?
Is there any way to test the MAF Sensor? I purched the "test tool" from MAD that plugs into the harness at the sensor & allows you to measure voltage at each lead with the engine runnning. No instructions were provided on what the readings should be. Can anyone advise?
Old Feb 26, 2004 | 12:03 PM
vader86's Avatar
vader86
Default Re: L98 MAF Sensor Testing? (geezel)
What were the readings?
Why did you think the MAF was goin south?
Old Feb 26, 2004 | 12:06 PM
timmytcc's Avatar
timmytcc
quick way to test it is with car running unplug it, if it runs worse, the MAF is fine, if runs better, get out your wallet.
Old Feb 26, 2004 | 01:05 PM
geezel's Avatar
geezel
Default Re: L98 MAF Sensor Testing? (vader86)
I havn't taken readings yet. I'm wondering if a bad MAF could have anything to do with the "lurching" problem I'm having. I you say, try and drive in 1st gaer at, say, 5 mph, the car begins lurching so bad you have to depress the clutch for it to stiop. It's always done it, prior to and after the new cam.
Old Feb 26, 2004 | 01:48 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Sorry about it being a lil' dirty. I have used it before. :thumbs:
http://temp.corvetteforum.net/c4/joh...structions.jpg
[Modified by War Machine, 12:49 PM 2/26/2004]
Old Feb 26, 2004 | 03:26 PM
geezel's Avatar
geezel
Default Re: L98 MAF Sensor Testing? (War Machine)
It looks like I need the following for an '86 L98:
1 Location of ECM connector from the MAF (Refer to GM shop manual).
2 Voltage equirements for each MAS pin (Refer to GM shop manual).
Can anyone provide this information?
Old Feb 26, 2004 | 04:38 PM
JAKE's Avatar
JAKE
Stand on the passenger side of the car, right under the MAF you'll see the connector.
Voltages will take a bit because I'll have to track down my Shop Manual.
Jake
Old Feb 26, 2004 | 05:49 PM
Pete K's Avatar
Pete K
Default Re: L98 MAF Sensor Testing? (JAKE)
One quick test for maf is the screwdriver handle test. With engine running give maf a decent couple of shots with the handle. If engine sputters and/or stalls its bad for sure. This caveman test will not prove that the sensor is good though. :smash:
Old Feb 26, 2004 | 07:39 PM
Sam Lam's Avatar
Sam Lam
I have a "clean & readable" copy of the MAD test device that I can send to you as a jpeg file. Using my "limited" recall, I do not believe the MAD instructions give you the good vs bad readings. Send me your email address if you want the copy.
SAM
[Modified by Sam Lam, 6:41 PM 2/26/2004]
Old Feb 26, 2004 | 07:47 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: I don't think the MAF is the answer to "lurching"
I have recently had a lot of experience with the MAF :rolleyes:
MAF controls fuel air mixture! Engine will run lean or rich with malfunctioning MAF and will run base timing "limp home" with no MAF
Yes the MAF can switch from lean to rich and back pretty quickly, but probably not quickly enough to produce "lurching"
Sounds to me like a rapid on and off of fuel or ignition...curiously, the MAF relays (not the sensor) are wired into the fuel pump systemthrough the ground circuitry (don't ask me how, but the book says so)
I had MAF relays going bad and I got a rapid on/off of the fuel pump, which caused momentary engine cut out, but not "lurching"
Do you have a shop manual? I was fortunate enough to find a scan tool from a fellow Forum member and that saved me a lot of time.
:seeya
:steering:
PS I have the test tool you mentioned and I didn't use it because it seemed like the connections were touching each other and would be too easy to short each other out
[Modified by jackdaroofer, 7:52 PM 2/26/2004]
To L98 MAF Sensor Testing?
