Fixed one problem, created another
Old Feb 27, 2004 | 08:09 PM
twofingerdoug's Avatar
twofingerdoug
Cruising
Default Fixed one problem, created another
I was able to fix my a/c problem on the dash, but while I was putting the dash cover back on I put the shifter in neutral and the emergency brake on, now the emergency brake is stuck. The button will not push in and the lever moves up and down with no resistance. Does anyone have any suggestions? :confused: :confused:
1986
Old Feb 27, 2004 | 08:23 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Fixed one problem, created another (twofingerdoug)
The lever is supposed to move up and down when the brake is engaged, it would be a little more difficult to get out of the car with it up :jester
Try pulling up on the handle while pushing the button in.
Old Feb 27, 2004 | 08:30 PM
twofingerdoug
Cruising
As Isaid above the button will not push in at all, just free play with the handle up and down.
thanx
Old Feb 27, 2004 | 08:52 PM
JCAIRE2's Avatar
JCAIRE2
So the handle will move to the top of its travel with no resistance? And you can't pull it up anymore while pushing on the button?
When brake is set and the handle is anywhere between the bottom of travel, and where the brake is set, you shouldn't be able to push the button. Only when you reach the spot where the brake is set, should the button move.
Old Feb 27, 2004 | 08:58 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Fixed one problem, created another (JCAIRE2)
I'm pretty sure on my 86 I can release it in any position.
Good Luck
:cheers:
Old Feb 27, 2004 | 08:59 PM
lspalding's Avatar
lspalding
Apply pressure to the release button, and then pull up on the handle. Hard. The button will go in. KEEP pressing it in, and lower the lever. You'll be fine.
Old Feb 27, 2004 | 09:05 PM
lspalding's Avatar
lspalding
Should have said: Bring the lever up to the top of the free play, and then follow my instructions. It'll make sense to you after the first time.
Old Feb 27, 2004 | 10:14 PM
twofingerdoug
Cruising
Default Re: Fixed one problem, created another (lspalding)
You were right, it worked, really appreciate it. This forum is great :)
To Fixed one problem, created another
