This is bad right??
Old Feb 28, 2004 | 03:52 PM
8835thL98's Avatar
8835thL98
Default This is bad right??
I was looking over everything closely, to see if all vacuum lines and hoses were connected, and i was messing around with the spark plug wires because i was going to replace them today. Anyhow, I noticed that the rotor wasn't pointing towards the number one spark plug tower. Am I right? Which end of the rotor is supposed to be pointed towards the number one tower? Also how do I re-adjust this problem so my timing matches up? Can someone help?? Pics are available below......Thanks!
Old Feb 28, 2004 | 04:01 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: This is bad right?? (-=Persephone=-)
The rotor will be facing whatever terminal it was pointing at when you turned the car off. If you have #1 cylider at TDC then you have problems. Engines don't fire off #1 cylinder to start.
Old Feb 28, 2004 | 04:03 PM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
Default Re: This is bad right?? (JCAIRE2)
:yesnod:
Old Feb 28, 2004 | 04:05 PM
8835thL98's Avatar
8835thL98
Default Re: This is bad right?? (My 95)
Anymore explanation?
Old Feb 28, 2004 | 04:11 PM
Trog's Avatar
Trog
An engine doesn't stop on #1 fire position every time it shuts down. It will stop turning at any random point. You would need to bump the engine over till:
a) the timing pointer on the front harmonic balancer is at zero &
b) the valve train is in the right position for firing the plug...
Remember with a 4 stroke engine the piston comes to top dead center (TDC) twice, once to fire for the power stroke & once at the top of the exhaust & start of the intake stroke. Thats why you can have the timing mark at zero but the rotor is 180 degrees out firing the #6 cyl instead because the #1 is at the exhaust stroke.
Old Feb 28, 2004 | 04:16 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: This is bad right?? (Trog)
:iagree:
Old Feb 28, 2004 | 04:20 PM
VettBrat's Avatar
VettBrat
The rotor spins inside the distributor cap. When you shut your engine off it can stop pointed at any point on the cap. The only time the rotor has to be pointed at number 1 is when you initially install the distributor. The rest of time it does not matter where it points.
Old Feb 28, 2004 | 04:23 PM
8835thL98's Avatar
8835thL98
Default Re: This is bad right?? (VettBrat)
Thanks Everybody! :party:
Old Feb 28, 2004 | 04:25 PM
B84RADR's Avatar
B84RADR
I assume the car still starts and runs though, or will it not?
Old Feb 28, 2004 | 08:09 PM
GS057's Avatar
GS057
2018 C6 of Year Finalist
Default Re: This is bad right?? (sspackman)
:confused:
Old Feb 28, 2004 | 08:49 PM
Caboboy's Avatar
Caboboy
What they're saying is..........you're OK if you didn't pull the distributor out :cheers:
Old Feb 28, 2004 | 08:53 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:D :D :D Does the light in your refrigerator go out when you close the door? :cheers:
Old Feb 28, 2004 | 08:57 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Default Re: This is bad right?? (jackdaroofer)
:lolg: :lolg:
B84RADR's Avatar
B84RADR
That's what little brothers are for. Stick them in and ask them.
SouthernSon's Avatar
SouthernSon
No one in my house seems to know how to close the $&*^$ refrigerator door!
Old Feb 28, 2004 | 08:59 PM
Caboboy's Avatar
Caboboy
You're a bad man, Mister Roofer........ :D
Old Feb 28, 2004 | 09:06 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: This is bad right?? (Caboboy)
:D I have become a "new age" mechanic...# 1 is wherever you want it to be! :D
To This is bad right??
Old Feb 28, 2004 | 09:10 PM
Caboboy's Avatar
Caboboy
Or........if the car belongs to a Psychologist, #1 is wherever it wants to be :lol:
Hope all's well Jack.....................long time no talk :cheers:
Old Feb 28, 2004 | 09:16 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
All is pretty cool :D Busines is a hazzle right now with steel prices going through the roof, but with about 7200 and wake up. can make it :D
What's new with you?
:seeya
:steering:
Old Feb 28, 2004 | 10:12 PM
86PACER's Avatar
86PACER
:jester
