Crank main bearing clearance
How much rod side clearance is allowed?
In the repair manual it say .006”--.014”
Mine is using 6” Eagle H-beam rods and Cola 3.875” crank .022--.026”
Is this still okay and if not, how can I correct this???
I also measured the crank main bearing clearance and it’s way more than allowed; it's about at .0033". max. allowed .0028".
Does anybody know of any shop that purposely uses that much clearance for some reason??
I ordered a set of .001” undersize bearing, these should bring the clearance down to a normal range.
For any info I would be very grateful.
Arnold
Standard clearance for high RPM small block main bearings is .0025 - .0030 the extra clearance of say .0030 provides for a thicker film of oil for high RPM/ heavy load operation. I previously had set my clearance at .0025, during this winters rebuild I set them to .0027-.0030 with the .0003 variation in the bearing shells.
Personally I think the .001 under main bearing you ordered will reduce your clearance too much as you would be .0018 - .0023 make sure you are using a calibrated bore gage & micrometers to take these readings
More bearing clearance = need for more oil volume to keep the oil pressure up which in your case will cause even more oil to spray from the increased rod side clearances onto the cylinder walls
Just my opinion, donÂ’t mess with the big cube motors much maybe some one else will chime in
-Jim
[Modified by superlund, 10:40 AM 2/29/2004]
Just my opinion, don’t mess with the big cube motors much maybe some one else will chime in
-Jim
For the rods, besides the oil control problems associated with large rod side clearances, you can have the rods twist on you under high loads.
At work, we sent main clearances to .0030 maybe a little tighter for a street motor. If you put 1's on there your clearances will be too tight and you'll probably be replacing bearings in short order. What brand of main bearings are you using?
What kind of rod bearings are you using? Is the chamfer on the outside of the rod journal larger than normal? You might need an H-spec bearing for the rods, has a larger chamfer to go with a race prepped journal chamfer.
[Modified by JCAIRE2, 12:57 PM 2/29/2004]
I'm going to see if I can get the main clearance set to about .0023-.0027 by using only the upper half or both halfs of the undersize bearings. I've done this before on my 350cc 400 hp engine for all bearings and it works great, 15k miles so far. We do this at where I work, the largest engine plant in the world, on all engines. We have 4 different sizes for rod and main bearings and mix these accordingly.
The main bearings I used for measuring were new Federal Mogul std. 7081 CHBL / 522T.
The rod bearings are new Clevite 77 CB-663 H / 03C12CD1
Arnold
Planned to install an oil accumulator but ran out of time, thought I could sneak / get by with out it, ran some long 1 mile plus sweepers at 115-125 MPH. Car continued to run well found the problem during winter tear down / inspection...
Use Clevite “H” series bearings as well, oil was Mobil-1 15-50. This season going to try thinner viscosity synthetic oil to speed / improve oil drain back times
Yes mix & match bearing shells as needed during assembly; I feel anything over .0025 should be fine.
Arnold
Too bad you have H's on the rods already. Maybe you could call eagle and see what they have to say, also the crank manufacturer and see what they recommend.
That's a lot but, unfortunately there isn't much you can do about it. It's going to cause a lot of oil to be thrown on the walls, so you'll definitely need to run standard tension oil rings.
Wouldn't cause me a lot of concern though, if you run the Speed Pro SS 50U oil ring set.
Be sure to index the rings correctly for best oil control.
There are differing views on bearing clearances. Some like 'em tight, others, loose.
I prefer .003 to .0035 on the mains and .002 to .0025 on the rods. On small journal rods I like the high end of the spec.
Jake
[Modified by JAKE, 5:17 AM 3/1/2004]
yes that’s what I measured.
I just called our engineers from development & research and they told me, and that is what I also think, that the rod bearing clearance is responsible for how much oil is going to be thrown on the walls, as you say, and not the rod side clearance.
We have on our V10 cyl. engine even a larger rod bearing clearance than mine: .024-.028
BTW, I have Speed Pro rings but I don’t know which ones. I indexed the rings just as SRP suggested. The ring gap is set between .022-.026. That’s they way I bought them; I think that should be okay.
I only drive on the street and not on a track but nonetheless we have on most of our Autobahns no speed limits.
Arnold
couldn’t get back to you any sooner, it took me some time to get all this info together. I asked the engineers of all of these manufacturers to give me information pertaining their main bearing clearance, rod bearing clearance and rod side clearance.
Here are the tolerances measured at 68°F and also the remark that enlarging the bearing clearances will bring you nothing but LESS hydrodynamic pressure and more oil spraying all over the place!!!!!!
.........................Main b. clear.//Rod b. clear.//Rod side clear.
Volkswagen .........0009-.0017//.0009-.0017//.008-.016
Volkswag.Diesel..0010-.0020//.0010-.0020//.022-.026
Audi.....................0009-.0017//.0009-.0017//.008-.016
Bentley................0009-.0017//.0009-.0017//.008-.016
Bugatti.................0009-.0017//.0009-.0017//.008-.016
GM.......................0008-.0020//.0013-.0035//.006-.014
All engines except the diesel have their max. Hp at or over 6000 rpm
Volkswagen up to 450 Hp
Volkswagen Diesel 330 Hp
Audi up to 450 Hp
Bentley 560 Hp
Bugatti 1001 Hp
Arnold
[Modified by vettef6, 7:41 AM 3/4/2004]
[Modified by vettef6, 7:43 AM 3/4/2004]
