<----->What's my problem?????<------>
Old Feb 29, 2004 | 11:21 PM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Default <----->What's my problem?????<------>
Today was beautiful! The sun was out, the temp was up so I waxed the car and hopped in to take a drive. When I started it, it was a little hesitant to start. No big deal, sometimes like that. Got it started then the idle went way down and started to die. I revved the engine to keep it alive. When I began pulling out the car from the garage, it didn't feel like there was any brake pressure. I drove onto the street, definitely no power brakes and the engine idle kept way down around 500.
This is all very strange because I took a drive last night and it was fine. No signs what so ever. It's an 89 coupe 6spd with 70k miles. What could the problem be? Please help. :cuss :banghead: :cuss
Old Feb 29, 2004 | 11:31 PM
bogus's Avatar
bogus
Default Re: <----->What's my problem?????<------> (89Corvette6spdFX3)
check the power brake booster, or, the hose that supplies it with vacuum.
Old Mar 1, 2004 | 12:50 AM
McShagger's Avatar
McShagger
That does sound very strange... Im probably off the mark here, but could it be your serp belt? Was there anything else?
Old Mar 1, 2004 | 11:23 AM
89Corvette6spdFX3
Default Re: <----->What's my problem?????<------> (McShagger)
I've replace the belt about a year ago, but I suppose that could be it. It's very strange. I hope I can figure it out without spending my savings. I'm sure it's something fairly simple. :cry
Old Mar 1, 2004 | 12:41 PM
CFI-EFI's Avatar
CFI-EFI
How does the BELT affect either the idle OR the brakes??? Bogus's suggestion, addresses both. Good luck, and...
RACE ON!!!
[Modified by CFI-EFI, 10:43 AM 3/1/2004]
Old Mar 1, 2004 | 02:19 PM
89Corvette6spdFX3
Default Re: <----->What's my problem?????<------> (CFI-EFI)
So any ideas?
Old Mar 1, 2004 | 03:29 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: <----->What's my problem?????<------> (bogus)
:iagree:
Old Mar 1, 2004 | 03:31 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: <----->What's my problem?????<------> (JCAIRE2)
check the power brake booster, or, the hose that supplies it with vacuum. :iagree:
:withstupid:
Old Mar 1, 2004 | 03:37 PM
bogus's Avatar
bogus
Default Re: <----->What's my problem?????<------> (VictorRussell'92)
:withstupid:
is it me, or am I being ignored? :D
Old Mar 1, 2004 | 03:52 PM
ittlfly's Avatar
ittlfly
:withstupid:
:iagree: BTW, any codes?
Old Mar 1, 2004 | 04:01 PM
89Corvette6spdFX3
Default Re: <----->What's my problem?????<------> (ittlfly)
Nope, no codes. So would the power brake vacume adversely affect the idle? Why would the car be fine 12 hours before? I didn't run it hard or slam on the brakes either. :confused:
Old Mar 1, 2004 | 04:27 PM
8835thL98's Avatar
8835thL98
Check the brake booster vacuum connection and the one to the plenum. If you have no power brakes then this is signs of your brake booster going out, I experienced the same problem this past summer. Good Luck!
Old Mar 1, 2004 | 04:28 PM
rick lambert's Avatar
rick lambert
:iagree: :iagree: :iagree: :iagree: :iagree: Definetly vacumn, who knows when it's GOING TO HAPPEN :D you didn't read about mice did you! :lolg:
Old Mar 1, 2004 | 06:33 PM
89Corvette6spdFX3
Default Re: <----->What's my problem?????<------> (-=Persephone=-)
So, the brake booster would cause the engine to stumble? Is the booster hard to replace? I have a brake bias spring I bought from Ecklers, maybe this is the time to install it. Does it make much difference in the stopping power of the brakes?
Old Mar 1, 2004 | 07:53 PM
CFI-EFI's Avatar
CFI-EFI
Bogus,
I guess so. You and me, both. I tried to give you credit. I agreed with you and then he asked me if I had any suggestions???
If the hose to the booster is off or leaking, OR if there is a problem with the diaphragm, it will cause a vacuum leak, which will affect the idle. AND the brakes.
RACE ON!!!
Old Mar 1, 2004 | 07:57 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
I will say what MOST everyone else has said...vacuum! :thumbs: Good Luck!
Old Mar 1, 2004 | 08:22 PM
bogus's Avatar
bogus
Bogus,
is it me, or am I being ignored? I guess so. You and me, both. I tried to give you credit. I agreed with you and then he asked me if I had any suggestions???
I feel your pain... and appreciate the support. :thumbs:
So, the brake booster would cause the engine to stumble? If the hose to the booster is off or leaking, OR if there is a problem with the diaphragm, it will cause a vacuum leak, which will affect the idle. AND the brakes.
RACE ON!!!
Let's review... what happens when there is a vacuum leak? the mixture leans out like a ****.
power brakes, for the most part, are powered by what? VACUUM. Vacuum, unless otherwise noted, is provided by the intake manifold.
Now... let us take these 2 items and put them together.
If the hose decides to break, you will lose power brakes.... and the engine will run like crap. if the booster blows up, you will lose power brakes and the engine will run like crap.
Finally, the bias spring goes into the master cylinder.
this concludes this lesson. :rolleyes:
To <----->What's my problem?????<------>
Old Mar 1, 2004 | 09:01 PM
dzierke's Avatar
dzierke
Default Re: <----->What's my problem?????<------> (Bruthish)
Plug off the vacuum from your brake booster. Start your engine and see if your idle is stable. While it's running check that vacuum line for cracks. If it turns out that your booster is bad, I would also replace your master cylinder. If you have had to top off your brake fluid lately, my guess is that fluid is leaking through the back of the master cylinder and drawn into the booster. Brake fluid is corrosive and can cause your booster to fail. This happened to my Vett a few years back.
Replacing the booster isn't all that hard to do. I recommend that you remove the 2 nuts holding the master cylinder to the booster and check for brake fluid moisture. If you don't see any wet spots then carefully pull the master cylinder away from the booster so as not to bend the brake lines. There are 3 or 4 nuts that hold the booster to the firewall inside plus the brake peddle linkage. It's abit tight inside but you can get to those nuts with a deep well socket, swivel and extensions lying on your back.
Good luck.... :thumbs:
Old Mar 1, 2004 | 09:18 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
:withstupid:
sure seems like it....
Old Mar 2, 2004 | 01:50 PM
89Corvette6spdFX3
Bogus,
RACE ON!!!
There have been some interesting replys in here. Apparently I need to respond to someone because he thinks I'm ignoring him. First of all Bogus, don't be a jerk. A little clarification and how-to would be nice but the sarcasm and king of all corvette owners' attitude can be kept to yourself.
Secondly, my first thought when this happened was to check the brake booster line which turned out to be fine. It was the first thing I checked even before I posted. I'm not a complete idiot as you would like to think.
I also didn't know I couldn't ask a simple question about the bias spring.
As for dzierke, thank you for not going off on me. A little advice towards how to check these things is greatly appreciated! I thought that was what this place was about. Not ripping other vette guys apart.
:skep: :rant: Okay, I'm done.
