Muffler question
Old Mar 1, 2004 | 09:51 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Default Muffler question
I want to modify my exhaust system, I can afford to spend about $300...my question is would I get more horsepower gain by eliminating the mufflers and having straight pipes versus installing something like flowmasters?
Thanks for input
:auto:
Old Mar 1, 2004 | 10:04 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Muffler question (ir0nmaiden420)
Just eliminating mufflers would be cheaper but about the same power gain as with free flowing mufflers.
However, I would start with a 2 1/2" mandrel-bent front Y and work back to the cat-back. A good local exhaust shop should be able to do both jobs in your price range. Later, round it out with a good hi-flow cat or "test pipe".
Old Mar 1, 2004 | 10:06 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
By removing my mufflers and replacing with straight pipes I actually lost some power, about 1.5 mph in the 1/4 mile.
I then went with a Corsa cat-back and gained it back.
Old Mar 2, 2004 | 08:31 AM
Kizmo's Avatar
Kizmo
Default Re: Muffler question (Mr Mojo)
You can get the Magnaflows for $335.00 from performance peddler. These are good high performance mufflers, straight through design, stainless steel with true dual tips. They are easy to install yourself and they’ll provide you with a performance gain. They will be somewhat louder then your stock system though. Just my $2 worth.
To Muffler question
