Yet another idle problem
Old Mar 2, 2004 | 04:25 PM
86Coupe's Avatar
86Coupe
Default Yet another idle problem
Went to lunch today, no problem, car running fine, on my way back, stopped at a light and the car died. Gave it gas, started it up, runs smoothly enough, but only when I give it gas, I let off the gas, it instantly dies. Haven't made any adjustments to the TB, but wonder where to start first? Is it more likely the IAC or the TPS? No codes set as of yet, but I have heard IAC won't always throw a code. The car will get limped home, and then I run and get parts for it with my Jepp, have an IAC and a TPS waiting, but which should I try first?
Thanks in advance
Old Mar 2, 2004 | 05:10 PM
86Pacecar's Avatar
86Pacecar
Default Re: Yet another idle problem (86Coupe)
Clean the IAC and TB first before replacing parts.
Old Mar 2, 2004 | 05:18 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I would pull and clean the IAC; there is a method on my site to reset the IAC & TPS.
If that doesn't fix the problem replace the IAC.
Old Mar 2, 2004 | 05:45 PM
VetteBandit's Avatar
VetteBandit
IAC is a good place to look, but Im still thinking TB is a good chunk of the problem. If it hasnt been cleaned ever it can really mess up your O2 sensor and get you some "nice" idle/air issues. Good luck I think your on the right track with the IAC but I think the TB will get ya moving again. Just my $.02
Hope your not gassin her in Neutral otherwise your gonna have a gonzo clutch ta-boot! :(
To Yet another idle problem
