Pushrod Guideplates Stepped or NOT???
Old Mar 4, 2004 | 08:11 PM
corvette1990's Avatar
corvette1990
Default Pushrod Guideplates Stepped or NOT???
I was lookin at new Summit Catalog and noticed that some companies offer stepped or flat hardened pushrod guide plates. Not knowing why there is a difference, maybe someone can enlighten me. I am guessing that the stepped ones guide the pushrod to less wobble closer to the rocker arms. Is this desirable? The stock ones on it now (that I have been told are just for GM assembly and not for Comp Cams Magnum roller rockers) are flat. Do my GM stock D113 heads have screw in studs? Thanks for the info, as always...
Chris :flag
Old Mar 4, 2004 | 08:15 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Pushrod Guideplates Stepped or NOT??? (corvette1990)
I used the Comp Cams raised hardened guide plates with my ProMagums as they are closer to the rocker arms and I felt that would give better guidence.
You will also need some hardened push rods for roller cams as well as a little light assembly lube for the ends of the push rods, sides of the push rods and tips of the valve stems.
Old Mar 4, 2004 | 09:12 PM
corvette1990
Default Re: Pushrod Guideplates Stepped or NOT??? (65Z01)
hey tks alot. I remember when you reccommended Level ten trans to me.....its still in there......
Old Mar 5, 2004 | 12:36 PM
1MoorTym's Avatar
1MoorTym
Do my GM stock D113 heads have screw in studs? Thanks for the info, as always...Chris :flag
Yes they do
Old Mar 5, 2004 | 01:05 PM
65Z01's Avatar
65Z01
You're quite welcome.
I too still run the Level-10 PTS-3 in the IROC but have found a good shop in CT, Grant Transmission, that built a great A4 in the Vette for about $600 less than Level-10.
To Pushrod Guideplates Stepped or NOT???
