Now that the plenum is off I might pick up a Holley AFPR since that's what most recommend. What size torx do you need to remove the stock FPR? Is it as simple as unbolting the stock one and pulling the fuel lines? I haven't depressurized the system so will I get fuel spraying everywhere? It doesn't look too hard but I want to get an idea of what to do!
T10 security torx bit. The one with a hole in the center of bit.
Remove vacuum line.
Remove torx screws. The cap is under spring pressure so be careful you don't let the pressure tear some threads when you get down to the last couple of screws.
Remove cap,spring and diaphram
Install Holley diaphram, noting which is the correct side up.
Install spring
Install spring washer
Install cap and reinstall torx screws
Install vacuum line and your done.
Of course you will have to put a gauge on rail and set your pressure.
:cheers:
The only catch (at least on my application) was that the adjusting wheel didn't quite clear the bottom of the plenum. I had to grind some material off the plenum in that area for it to clear. It wasn't anything that a few minutes with a dremel couldn't solve :cheers:
You don't have to unhook the fuel lines, you should let the pressure out of the system. Loosen the gas cap and let the car sit for several hours would help, there is a fitting on the rear passenger side fuel rail where you read the pressure that you can also use it to relieve pressure, it should be under a little metal cap.
It would be best if you had measured fuel pressure before removing the plenum but try 44psi to start with.
Be sure to relieve fuel pressure at the Schraeder before opening the FPR.
During installation press the cap into place and hold it there as you tighten the TOrx screws. Tighten them in succession with firm pressure but be careful to not strip the threads as they are rather fragile.
Just another quick note - When I installed my Holley the car initially would not start. - Adjusted the fuel pressure up on regulator and she purred like a kitten. The Holley can be adjusted to almost no pressure and if it is installed that way the car will not start.
Just be aware of this since you cannot get a good pressure reading until the car starts.
Is that 44psi with the vacuum line disconnected? Do you test the pressure with the engine idling, or is that once you turn the key on but with the engine off?
