Vortex Rammer Cold Air System??
Old Mar 6, 2004 | 11:14 AM
JB666's Avatar
JB666
Default Vortex Rammer Cold Air System??
Ok, I've been presented with an opportunity to get this setup for a fraction of the cost, and I'm wondering if it's THAT much better then running a K&N W/Open lid?? That's what I'm running now, and the person selling this is telling me it's "night and day" from my setup. Correct me if I'm wrong, but aren't I restricted , at my TB, to how much air I CAN suck in??? He says "hey, if nothing else, it SOUNDS really cool". I just can't justify spending that kind of $$ on a cool sound - if I could, I'd put some of those really cool whistle tips on my new Corsa's when they come
:lol:
Old Mar 6, 2004 | 11:17 AM
Perfusion's Avatar
Perfusion
Default Re: Vortex Rammer Cold Air System?? (Jbaker)
From what I've heard (although I can't speak from experience) is that it won't do much for you from a standstill. I guess it's best used at highway speeds when you need to pass somebody. Of course, I've never had a problem passing *anybody* - I just gotta push the pedal on the right far enough down. That's the beauty of 5.7L!
Old Mar 6, 2004 | 11:20 AM
JB666's Avatar
JB666
Default Re: Vortex Rammer Cold Air System?? (Perfusion)
That's what he was saying,that it opens up the car on the highway. That, I can see, because it'd be taking in a LOT more air then from the (hot) engine compartment on a 95 degree summer day (WHERE ARE THESE DAYS?!?!??!?!?!?! :banghead: ). I'm just left wondering if it'll matter, with all this new air, and the stock TB?
Old Mar 6, 2004 | 12:16 PM
kman0066's Avatar
kman0066
The stock TB can flow a lot more air than a 350 will need. That is not an issue, the question of Ram-air is debatable, but in theory it makes sense, but it's kind of hard to Dyno a car while it's traveling at 70mph.
I remember an article about the old Camaro and Trans Am LT1's. They were testing the two against each other and the Trans Am had ram-air. Well, after a 100mph the Trans Am started to pull away. The article questioned if it was the ram-air or just the better aerodynamics of the Trans Am. I doubt you'll see a night and day difference, but I imagine it would help a tiny bit.
Old Mar 6, 2004 | 12:29 PM
Xssesive's Avatar
Xssesive
Default Re: Vortex Rammer Cold Air System?? (kman0066)
I dynoed my 98 with a Vortex breather on it the first run and had 306HP, thinking the breather might be costing me HP, removed it and actually lost 6HP! That was with the car not moving! I think people under estimate the true potential of forced air! :yesnod:
PBnf's Avatar
PBnf
He's right, there is no way to tell other than to put the system on your car and compare it to it's "stock" performance. I doubt that the guy will let you do that, but also the fact that your getting cooler, outside air has to be good for ne at highway speeds. Just my two cents.
Old Mar 6, 2004 | 12:36 PM
JB666's Avatar
JB666
Default Re: Vortex Rammer Cold Air System?? (PBnf)
No, he won't - it's buy, or bye. I'm leaning towards going with it, because, in theory, it's a good setup. It doesn't suck air from your hot engine compartment, and, as stated earlier, the faster your moving, the more air is getting directed in.
He did say, of course, the front plate/ram air setup is the BEST, but we have front plate laws, and I don't need the extra attention to the fact that I never run my front plate :jester
Couldn't you almost simulate highway speeds while on a dyno by forcing air up to the filter assembly with a high powered fan??? Also, by just cutting your shroud open, how much air CAN get up there? I've never seen one cut, so I don't know how big the opening is.
Old Mar 6, 2004 | 01:48 PM
vader86's Avatar
vader86
Its pretty much useless.
Old Mar 6, 2004 | 05:40 PM
JB666's Avatar
JB666
Default Re: Vortex Rammer Cold Air System?? (vader86)
What are you basing this on?? I'm not saying your wrong, but in searching through the archives, I've seen people posting some pre/post dyno results, but I can also see that you have kept your opinion pretty solid about this product - so I want some more info... Bad experiences with Breathless products, or this one in general?? This is the type of stuff I'm looking for :thumbs:
Old Mar 6, 2004 | 05:44 PM
vader86's Avatar
vader86
Every dyno result posted show minimal gains, as do 1/4mi ETs.
I dont see it as being worth any more than a K&N Open lid, which itself doesnt seem to help LT1s much.
Breathless products have had problems with fitting under the hood correctly.
Old Mar 6, 2004 | 05:49 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
I have one on mine, but it was there when I bought the car. So, I can make no testimony to any HP or performance gains. I can say that it does fit under the hood. And that I cannot hear it sucking air.
That said, I am glad I have it already so I don't have to decide whether to spend the money on it or not. :D
JB666's Avatar
JB666
Well, I've read that they MAY have fixed this problem - I don't like MAY'S, so this will be a gamble.
As for the gains, wouldn't the (beaten to death, I know) the gains coming from cool(er) air from under the car, be far greater then sucking air from the engine compartment (open lid)?? Not to mention, as you speed up, your air supply increases, thus giving more air intake creating better performance. There's no way a stock housing/open lid can do that , because it's pretty much sealed under the hood.
Now, I'm not expecting 15-20 gains, as the company states, but, even if there was a slight SOTP gain, it'd be worth it. Not to mention, with the clear lid, it looks :cool: . NOT QUITE as cool looking as the Claw, but still the same.
My MAIN thing here is, I can get this for short money, so I figure, at this point, it's worth the gamble as long as I'm not expecting the world.
With all this extra air, maybe I shouldn't have given my Air Foil away
:jester
Thanks for your input, here. :thumbs:
Old Mar 6, 2004 | 05:51 PM
JB666's Avatar
JB666
Default Re: Vortex Rammer Cold Air System?? (LT-4 CE)
Do you have any other pics, of this installed, besides the two in your gallery?
Thanks!
Old Mar 6, 2004 | 05:53 PM
Perfusion's Avatar
Perfusion
Here's my final opinion. It seems like you are really tossed up about whether or not to get this thing because it's so cheap. I take it that if it were more expensive (retail), it wouldn't even be an issue...
I say you shoud pick it up, try it out, and if it doesn't work - unload it on eBay. You'll at least get your money back out of it, and maybe you'll get lucky and even profit from the sale. That's just my 2 cents, though, so take it with a grain of salt.
[Modified by Perfusion, 3:53 PM 3/6/2004]
Old Mar 6, 2004 | 05:55 PM
vader86's Avatar
vader86
Theoretically, the cold air should help, but in practice from ETs I dont remember a single person who said it helped that much.
You also make a tradeoff, the air going into the CAI is what is meant for your radiator, so the engine will run 10-20F hotter.
Old Mar 6, 2004 | 05:56 PM
JB666's Avatar
JB666
Oh, absolutely.. I could get my money back out of it, if I didn't like it. It REALLY isn't the main reason I'm getting it (price) - it's just that I'd like to try different air intake systems to see which one works best for me . I'm skeptical on some of the HP gains I've read in the archives, but at the same time, I can see this being effective. I just do NOT want to have fitment problems, and have to fight with something that's not of good quality :smash: . So yes, price is HELPING me decide, but it's not my only factor here.... :cheers:
Old Mar 6, 2004 | 05:58 PM
JB666's Avatar
JB666
I hadn't thought about that. Even being completely sealed, you believe that the engine temps could increase that much??? Do you mean the air escaping into the engine compartment, or the air getting sucked into the TB?? I DEFINITELY can't afford another 10+ degree increase, she runs hot enough as it is!!!!!
To Vortex Rammer Cold Air System??
Old Mar 6, 2004 | 06:15 PM
vader86's Avatar
vader86
The air going into this Vortex box and into the TB later is what is meant to go over the radiator. Youre adjusting the airflow with that big hole in the shroud.
Old Mar 6, 2004 | 06:36 PM
cprgmr's Avatar
cprgmr
I have the Vortex and I can tell you this... The first one I ordered and installed had some severe quality issues. The snorkel buckled under tightening and the plastic see through shroud melted a little.
With that said, the replacement they sent me is holding up a bit better. I'm thinking about ditching this thing and going with the one that goes in the front license plate...
Old Mar 6, 2004 | 09:06 PM
JB666's Avatar
JB666
Ok, I've been down in the garage tonight, taking my shroud out, and I can say I agree with you, IN PART. The area, where the hole will be cut, for the Vortex, is quite a bit in FRONT of the A/C condensor, and no where near the radiator. Yes, I'd be robbing SOME of the air going to the cooling system, but I don't think, when the car is in motion, I would be taking the hot air FROM the radiator. The opening, under the car, that feeds the condensor & radiator is of considerable size (now I see why all those leaves got sucked in between!!), and the area that the Vortex will be taking air large enough to "share", and is, from what I can see, one of the perfect places to have an intake(besides directly from the plate, yes). One thing I'm wondering is how hot this condesor gets in the summer??? I wouldn't imagine it being AS hot as the radiator?? Either way, the rear hole, for the Vortex, is about 2" in front of the condensor, and then depending on how far down the hole needs to be, is quite a ways from it, at that point - So, I see both points :thumbs:
Oh, and what a PITA getting that shroud off!!!!!!!!!!!!!!!!!!!! :banghead:
