engine bay heat, more on passenger side
Old Mar 7, 2004 | 01:23 AM
kwd1's Avatar
kwd1
Default engine bay heat, more on passenger side
Hi all,
I was getting a whiff of oil after shuting down and was trying to figure out where it was coming from. I was looking at the back/top of the motor right in front of the windshield. I noticed that there was alot more heat coming from the passenger side than the drivers side. Anyone ever notice this? Only thing I could figure to cause this is a difference in airflow due to obstructions.
On the left side it almost seemed too hot. Like if you were holding your hand close to a fire.
Ken
Old Mar 7, 2004 | 05:35 AM
NoWorries's Avatar
NoWorries
Default Re: engine bay heat, more on passenger side (kwd1)
How old are your cats? When my engine bay got super-hot it was due to a cat that came apart.
Old Mar 7, 2004 | 08:08 PM
kwd1's Avatar
kwd1
Default Re: engine bay heat, more on passenger side (NoWorries)
Cats are OEM. It's a 96 with 27k.
That's exactly what it sounds like it could be. However after reading your post I went out for about ten minutes to get it warm and the passenger side didn't overheat. Might not have run it long enough. I also 'quickly' touched each cat and they were about the same temp.
Besides the heat in the engine bay is there any other way to tell a cat is bad?
thanks
Ken
Old Mar 7, 2004 | 08:20 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
thanks
Ken
:cheers:
You can test exhaust back pressure, a clogged cat ought to show up.
I know how to do it on my 88, not sure where the "pipes" and stuff are on yours.
If you have a shop manual (good investment) it will take you thru the procedures and the outcomes
:seeya
:steering:
To engine bay heat, more on passenger side
