Grinding drip tabs
Mar 7, 2004 | 07:38 PM
Grinding drip tabs
Will this work to accomodate CC 1.6 roller rockers?
Mar 7, 2004 | 07:53 PM
Cruise-In II Veteran
Re: Grinding drip tabs (cprgmr)
From that pic it looks good to me.
How long is the longest drip tab now?
Mar 7, 2004 | 07:55 PM
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
I hope so. You ground them down farther than I did for my Crane 1.6's
Mar 7, 2004 | 07:59 PM
Re: Grinding drip tabs (65Z01)
They're pretty much flush with the bottom (top) of the cover. :)
Mar 7, 2004 | 08:12 PM
Yes, they'll work.
Mar 7, 2004 | 08:21 PM
Re: Grinding drip tabs (STL94LT1)
Quote:
Yes, they'll work.
:cool: Thanks!
Mar 7, 2004 | 10:53 PM
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I left probably 3/16ths on mine and they worked with bulky aluminum RRs and now with CC Pro Mags.
Mar 7, 2004 | 11:07 PM
Grinding ?!?!? I just broke mine off with vise grips... It looks like it will work.
Mar 7, 2004 | 11:37 PM
Re: Grinding drip tabs (BillWelter)
What the heck are the drip tabs for? I am getting ready to replace my RR as well and everyone has told me to grind down the drip tabs.
Mar 8, 2004 | 12:06 AM
Re: Grinding drip tabs (C490Vette)
They are to allow splash oil to drip back down on the stock stamped rockers. Not needed for full rollers.
Mar 8, 2004 | 12:52 AM
Always better to score a line on the tabs with a Dremel then break. For me its 100% done with a Dremel.
Mar 8, 2004 | 12:59 AM
Re: Grinding drip tabs (GRX)
That's how I did mine too. Really puts out some bodacious dust, doesn't it? :U
Mar 8, 2004 | 01:06 AM
Re: Grinding drip tabs (Corvette Kid NC)
Yep. Afterwords a complete water bath is in order :yesnod:
Mar 8, 2004 | 09:03 AM
Yep, I did mine with the good ole Dremel cutting wheel. :thumbs:
Mar 8, 2004 | 09:56 AM
:iagree: So much so that I brought the vacuum cleaner over to the work bench and I hold the nozzle in my left hand and use the Dremel in the right. It really cuts down on a
lot of the dust! :)
