roller rockers?
Old Mar 8, 2004 | 02:33 PM
mphy98's Avatar
mphy98
Default roller rockers?
how much hp do you actually gain with roller rockers? :steering:
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: roller rockers? (mphy98)
10-15rwhp is wht I have heard here. :yesnod:
Old Mar 8, 2004 | 02:35 PM
BowTieBlood's Avatar
BowTieBlood
Default Re: roller rockers? (VictorRussell'92)
:iagree:
Old Mar 8, 2004 | 03:21 PM
Midnight89's Avatar
Midnight89
Default Re: roller rockers? (BowTieBlood)
I'm hoping its 10-15. From everyone I've talked to, 10-15 seems to be the consensus.
Old Mar 8, 2004 | 03:25 PM
jstkrsn's Avatar
jstkrsn
I got 12 HP from my add on.
Old Mar 8, 2004 | 03:45 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You can expect 15chp from 1.6:1 RRs on intake & exhaust on a late L98 and from 1.6:1 RRs on intake with 1.5:1s on exhaust for an early L98.
Old Mar 8, 2004 | 04:08 PM
johnnyevans's Avatar
johnnyevans
Default Re: roller rockers? (65Z01)
12-15 CHP is realistic going from 1.5 to 1.6 RR. If the stock rockers were real bad, you might get a few more. It's a good change, easy, can't say inexpensive.
Buy good ones tho'. Look what happened to the Jegs car this past weekend with his RRs. Granted, most of us aren't running those lifts or spring pressures, BUT, ours run a lot longer and RPMs a lot more varied and wider range than his, and we subject them to a lot more heat variations. Don't think for a second that valve float won't tear up a rocker, pushrod or valve.
Not preaching, they are a good bang for the buck that can be used in more situations than a lot of other aftermarket parts.
Old Mar 8, 2004 | 04:47 PM
redcorvettedave's Avatar
redcorvettedave
Default Re: roller rockers? (johnnyevans)
QUOTE----------------------------------------------------------------------
WHAT HAPPEN???? :confused:
Old Mar 8, 2004 | 06:04 PM
65Z01's Avatar
65Z01
Default Re: roller rockers? (redcorvettedave)
A failed rocker arm cost him big time in Pro Stock competition last weekend.
To roller rockers?
