From: Sarcasm. Just one of the many services I offer.
Gas test-regular was better
I just ran a test with my 86---filled it up with 87 octane, when the tank was empty the computer stated i was getting a little over 15mpg. I ran 93 octane and after the tank was empty i was getting 14mpg. The car also seemed to have more power with the 87 octane :auto:
Don't the L98's use knock sensors and an electronic spark control module to listen for knock and adjust timing as necessary? :confused:
Yes.
Not sure what youre getting at. Too much octane in an engine that doesnt need it can hurt performance, just like having not enough octane in an engine that does.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Re: Gas test-regular was better (vader86)
:iagree: Higher octane fuel actually burns cooler to prevent detonation in higher compression engines and so will definitely hurt efficiency in engines that don't need it.
What is going on is that low octane fuel is actually more powerful (but also much harder to ignite). That's a great thing up until you get premature detonation...but diesels don't have that problem by design.
So the lower your octane, the more torque that you get out of the fuel itself...right up until the point that you get premature detonation.
The cooler your engine runs (and the lower your compression ratio), the lower octane that you can get away with, up to a point, at least.
Combine those two things, take them to the extreme, and you pretty well come up with what nitrous oxide gives you: which is to say more torque at any given RPM.
So if you want better gas mileage, then run the lowest octane that you can.
But if high performance is what you want, then you want higher compression (and air is free, after all) in order to get more overall power (but this time from the air more than the fuel) out of each explosion in each cylinder.
Excuse me Mr Vader et al, what is the stock compression, 8.5:1, 9.5:1, I don't recall? And doesn't the General suggest 91 octane :confused: BTW the stroker is averaging 21.1 MPG, but I am kind of a Jekl&Hyde. I definately get into it when I like, several times a day in mixed driving conditions. 91 octane.
I can never remember, people keep telling different things.
I think its listed at 9.5:1 in the manual, I think. I dont have the 86 owners manual, so I dont know what octane is recommended. If I can remember to look it up tomorrow I will.
In my 85 manual I am pretty sure it just says 86/7 octane is needed. I've always run premium (93 around me), figure its cheap insurance. I've Plus I have the timing bumped up to 12 degrees.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Re: Gas test-regular was better (rsafier)
:iagree:
You're wasting your $$ running premium, and you're probably making less power. But if it makes you feel better, enjoy!
*psst!.. Your vette basically has a truck engine. Now tell me, if you had an '85 Chevy pickup, would you put premium in it? Or does the Corvette's pretty shape, low ride height, and tuck away headlights make it need premium?
Amazingly most that have posted, here, "get it". Many Corvette owners think that more, (especially, more expensive) is better. 'Tain't necessarily so! Case in point:
Iron headed 1984 - 1986, L83 and L98 engine have 9.0:1 compression ratio. Higher octane ISN'T cheap insurance. It's a waste of money AND performance. I have my base timing set a 14* btdc and use 85 octane gasoline.
[Modified by CentralCoaster, 1:16 AM 3/9/2004]
Wow I always thought premium was best for my '86 (iron heads). Maybe I'll try the lower grade and see if there's any difference.
The fuel has nothing to do with torque. Diesels have amazing torque due to the insane cylinder pressure and compression ratios. Torque isnt a function of fuel, its a function of engine design. The fuel simply allows the engine design to do it's work.
Octane doesnt give you more power, putting a higher octane fuel in an engine that doesnt need it doesnt do anything except waste money.
So what about 87 octane in an LT1? Is the extra 1.0 of comp (10.5:1 vs. 9.5:1) enough extra compression to bring about peak power with 93 grade, or would 91 or even 87 be worth taking a chance on? I always burn 93 grade in my LT1 :)
[Modified by Lone Ranger, 12:33 PM 3/9/2004]
:withstupid: :confused: Isn't premium recommended for the LT1?
