My miniram pics
Old Mar 9, 2004 | 09:51 AM
jerkyboy's Avatar
jerkyboy
Default My miniram pics
Got tired of looking at the mess of wiring etc... I am no fabricator but this is what I cam up with. What do you think?
Old Mar 9, 2004 | 09:52 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: My miniram pics (jerkyboy)
You LT-1 wanna be! :lol:
Just kiddin! That looks great! It looks strong! I like the powder coated valve covers. :flag :chevy :yesnod:
[Modified by VictorRussell'92, 8:53 AM 3/9/2004]
Old Mar 9, 2004 | 09:57 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
:cool: Looks Great :thumbs:
:cheers:
Old Mar 9, 2004 | 10:19 AM
jerkyboy's Avatar
jerkyboy
Default Re: My miniram pics (AGENT 86)
Before pic. yuk (and yes, that is my shoelace holding up the spark plug wire off the header)
Old Mar 9, 2004 | 10:41 AM
ZylaRace's Avatar
ZylaRace
What did you use for spark plug looms?
Replace the center bolt, bolt? (Or just thread it thru the loom?) i.e. How are they attatched?
Old Mar 9, 2004 | 10:59 AM
jerkyboy's Avatar
jerkyboy
Default Re: My miniram pics (ZylaRace)
Yes, they are looms from Summit that come with longer bolts. I screwed them down tight but the looms still moves a bit if you need to do some adjusting. Hopefully they will hold the covers tight enough to prevent leaks. Will see when I let it run after the o2 sensor goes in.
Old Mar 9, 2004 | 11:07 AM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Very :cool:
The MR leaves alot of wires/hoses exposed and no matter how nice the intake and valve covers look, the overall look is messy. You did a great job of covering it up.
[Modified by Ski2Tee, 11:25 AM 3/9/2004]
Old Mar 9, 2004 | 11:13 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Very good looking! :cool: :cheers:
Old Mar 9, 2004 | 11:39 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: My miniram pics (War Machine)
How did you mount the LT1 Covers?
I might have to do that. I like it.
Old Mar 9, 2004 | 11:51 AM
jerkyboy's Avatar
jerkyboy
Default Re: My miniram pics (-=Jeff=-)
Again, I will remind everyone that I am not a fabricator and this is going to sound goofy but I got some stainless hooks about 3" with 1/4 threads on the end. Hooked to vacuum inlet on the manifold. Used the Dremel to drill the hole on the cover. Cut off excess thread and used those nice bubble top nuts to tighten it down. Cut holes for AFPR , hoses etc... Here's the other side:
To My miniram pics
