Hooker -vs- TPIS Headers
Old Mar 10, 2004 | 05:04 PM
geezel's Avatar
geezel
Default Hooker -vs- TPIS Headers
I understand both the Hooker 2149's and TPIS headers will work well on my 86. I'm leaning toward Hookers simply because I can eliminate that crappy "clamp" style EGR tube connection that is on my stock manifold. The Hookers supposedly have a two bolt connection if I buy a later version EGR tube. Is this correct?
Also, are O2 bungs provided on both styles?
Old Mar 10, 2004 | 05:06 PM
rsafier's Avatar
rsafier
Default Re: Hooker -vs- TPIS Headers (geezel)
Hookers you need to get a Y-pipe for. The TPIS includes the Y-pipe and I know has the sensor bung installed, both the emissions and non-emissions versions. Don't have Hookers so can't comment. But pretty sure they do.
Old Mar 10, 2004 | 05:45 PM
1MoorTym's Avatar
1MoorTym
Hookers have the 02 welded in the number 7 primary, which some have used without any problems. I put a heated sensor in the Y pipe on the passenger side (more room there).
Yes the Hookers use a bolted egr (later style) pipe. Other differences are they also have a flange connection to the Y pipe instead of the slip fit that TPIS uses.
Old Mar 10, 2004 | 05:50 PM
geezel's Avatar
geezel
Default Re: Hooker -vs- TPIS Headers (1MoorTym)
Is the flanged connection to the front Y better than a slip fit? I've heard ceramic coatings can cause trouble with slip fits. What's the Chevy part # for the later style EGR tube? Can I buy one anywhere else?
[Modified by geezel, 3:51 PM 3/10/2004]
Old Mar 10, 2004 | 06:31 PM
vader86's Avatar
vader86
youll need the EGR tube for the 88-91 corvette
Old Mar 11, 2004 | 06:12 AM
86PACER's Avatar
86PACER
Default Re: Hooker -vs- TPIS Headers (vader86)
And it's GM part#14092329
Old Mar 11, 2004 | 07:32 AM
Red Tornado's Avatar
Red Tornado
The Hookers snug up pretty well underneath. Its my understanding that the TPIS headers hang a little lower.
Old Mar 11, 2004 | 07:43 AM
LD85's Avatar
LD85
Default Re: Hooker -vs- TPIS Headers (bradvette)
A few of the Hooker header bolt holes are very close to the tube OD's.
IF I bought them again, I would weld on a tublar extension over the bolt hole so it sticks out past the bend in the tube so you can get a good grip on the bolt.
You will be glad you did this little mod belive me.
Old Mar 11, 2004 | 01:52 PM
PBnf's Avatar
PBnf
Default Re: Hooker -vs- TPIS Headers (ld85)
Tell me more about this. What do you mean by a "tublar extension"?
Old Mar 11, 2004 | 05:07 PM
LD85's Avatar
LD85
Default Re: Hooker -vs- TPIS Headers (PBnf)
Well I would takea piece of solid round stock steel and drill a clearance hole thru it for the header bolt to go thru, or use a piece of pipe the correct size.
The OD would be @ 3/8" and the hole would be clearance for the 5/16-18 header bolt, the length would be @ 1-3/4 long and would stick out just past the bend in the header tube so you can get a wrench on the bolt head,,, some headers already have these welded onto them.
The way it is now 3-4 of the header mount hoels are too close to the header tube so you cna only turn the bolt @ 45 degrees,,,, I tried using socket head caps screws (SHCS) and they work OK till you get back to the passenger side rear bolt, then virtually nothing can be used back there to reach a bolt head. I cut off an Allen wrench and slip a 5/16 boxed end wrench over the allen piece and then use a pipe to crank it down.
Old Mar 12, 2004 | 12:16 PM
gcrouse's Avatar
gcrouse
Shouldn't you mainly be considering your application vs. header size?
Hookers have 1-3/4" primaries; aren't the TPIS only 1-5/8" ?
On a less modded car the 1-5/8" are usually better, especially for low and mid range torque.
Old Mar 12, 2004 | 12:42 PM
TheStef's Avatar
TheStef
Default Re: Hooker -vs- TPIS Headers (gcrouse)
ld85, I understand what you explained about the hookers headers and adding a tubular extension to give you some place for the bolt... but do you know if the TPI's are ok for this?
I plan on putting on a set of headers on my car this summer, but I don't want to do any welding on my brand new headers, "especially if their coated"
[Modified by TheStef, 11:51 AM 3/12/2004]
Old Mar 12, 2004 | 03:59 PM
86PACER's Avatar
86PACER
TPIS headers are also 1 3/4" :thumbs:
Old Mar 12, 2004 | 04:39 PM
LD85's Avatar
LD85
Default Re: Hooker -vs- TPIS Headers (TheStef)
I will ask Ol'RJ later tonight, he has TPIS on his car.
Old Mar 12, 2004 | 05:21 PM
rsafier's Avatar
rsafier
TPIS already has these "extensions", they are just like the stock manifolds in that respect. Coated price is a bit more then Hookers. I should finally have my set on Tuesday so I will be able to report in later that week about how the install went. From other posts I've read its pretty straight forward and no major problems. You can reuse all your stock supports (A/C & Alternator) unlike Hookers.
Old Mar 12, 2004 | 09:44 PM
LD85's Avatar
LD85
Default Re: Hooker -vs- TPIS Headers (rsafier)
"TPIS already has these "extensions"
:iagree: Ol'RJ came by tonight and said the same. The extrnsions are good but #8 is still a bear :seeya
Old Mar 15, 2004 | 09:13 AM
TheStef's Avatar
TheStef
Thanks guys, I'll be going with TPIS if the install is easier and more of a bolt on setup.
:cheers: :thumbs:
To Hooker -vs- TPIS Headers
