help with sensors.......
Old Mar 10, 2004 | 07:20 PM
GhosTRydeR_92's Avatar
GhosTRydeR_92
Default help with sensors.......
is it possible to test the 02 sensors and the knock sensors with the car in the on position (not running) and if so what voltage should i get for the 2 sensors an what should i set my digital meter on, ohms ???
thanks for helpin guys ??
:cheers:
Old Mar 10, 2004 | 08:05 PM
GhosTRydeR_92
Default Re: help with sensors....... (GhosTRydeR_92)
:nopity
Old Mar 10, 2004 | 09:54 PM
GhosTRydeR_92
geez someone help :banghead: :cry plzz
Old Mar 10, 2004 | 10:27 PM
jfb's Avatar
jfb
The knock sensor is like a microphone and only puts out a voltage when knock occurs in the cylinders. Without the engine running, the knock sensor has no output and cannot be told if it is defective or not. The O2 sensor puts out a voltage, 0.1 volts high oxygen (lean) to 0.9 volts low oxygen (rich). A 10 megohm per volt or higher voltmeter is required to make the measurement. The O2 sensor needs to above 400 F before an accurate measurement can be made and codes are set if the sensor is open circuit or puts out a voltage outside of 0.1 to 0.9 volts.
Old Mar 10, 2004 | 10:48 PM
GhosTRydeR_92
Default Re: help with sensors....... (jfb)
thank you so much jfb! thats all i needed to know uve been a great help :thumbs:
Old Mar 11, 2004 | 09:47 AM
dwestsr's Avatar
dwestsr
One way to test the knock sensor is to hook up a timing light and have someone tap lightly on the blockwith a small hammer and see if the timing retards
Old Mar 11, 2004 | 09:49 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: help with sensors....... (dwestsr)
Or you could get a scanner. :yesnod:
Old Mar 11, 2004 | 04:03 PM
GhosTRydeR_92
Default Re: help with sensors....... (VictorRussell'92)
ive got a datamaster :confused: would that work ? :cheers:
Old Mar 11, 2004 | 09:50 PM
Sam Lam's Avatar
Sam Lam
I think it would help!!! You can buy a little wiring adaptor at MAD that allows you to test the O2, but the engine has to be running. :)
SAM
Old Mar 11, 2004 | 10:00 PM
Black87c4's Avatar
Black87c4
Default Re: help with sensors....... (Sam Lam)
You should get codes if either of them is not working.
Old Mar 12, 2004 | 12:33 AM
GhosTRydeR_92
SAM
i made one :D havent used it yet tho :cheers:
To help with sensors.......
