I have a rebuilt 87' / ZZ4 engine in my 84' with 7K miles on it. Question I've used about 1/3 Quart of Mobil 1 5W30 in a little over 4,000 mi. Is this about Normal?
The best place to find your answer is from the machinest. Oil clearances vary and I match oil to bearing clearance.temp matters also but I would check the clearance
