160 degree thermostat
Old Mar 11, 2004 | 01:11 PM
85loub's Avatar
85loub
Default 160 degree thermostat
Anyone running a 160 degree thermostat with no other mods. I recently added a new cooling swith, on 200 off 185. Fan obviously runs alot. Car runs 184 at cruise goes up to 200 quickly at idle. Fan kicks on fine, doesn't like to kick off until about 175. 180 degree thermostat makes it difficult to get there. I have new waterpump, radiator, thermostat, cooling switch and flush and filled antifreeze this weekend. I am not concerned at the temps the car runs. Oil gets to 220 at steady highway cruise. Just wanted to know if anyone else was running 160 stat with no mods and no problems. :confused:
Old Mar 11, 2004 | 01:30 PM
MostWanted's Avatar
MostWanted
Default Re: 160 degree thermostat (85loub)
I'm running a 160 degree thermostat and the only thing I have really done is reprogram the computer with the Hypertech Power Programmer III. Instead of an actual switch, the computer now cuts the fan on earlier. I have never over heated since I have done this. In other words, I can't foresee a problem if you put in a 160 degree stat.
Old Mar 11, 2004 | 01:32 PM
BowTieBlood's Avatar
BowTieBlood
You'll see no issues running it alone. Your fans won't turn on sooner though (like the programmers provide you with), but just putting a new temp guage in there won't hurt anything :cheers: done it many times.
Old Mar 11, 2004 | 01:36 PM
CFI-EFI's Avatar
CFI-EFI
Your operating temps are great. Get a fan switch that turns in and off at higher temps. Maybe on at 210 to 220, and off at 195 to 205. All you are doing now is putting unnecessary wear and tear on your fan motor. You probably won't notice any immediate problems with a cooler stat, but the lower operating temps and prolonged warm up will take a slow steady toll on your engine. If you don't need cooler temps for a specific reason, such as max effort while racing, stay away.
RACE ON!!!
Old Mar 11, 2004 | 01:43 PM
vader86's Avatar
vader86
I run a 160 and have reprogrammed fans, my oil wont get to 220 except during summer with AC on.
Old Mar 11, 2004 | 01:51 PM
MostWanted's Avatar
MostWanted
Default Re: 160 degree thermostat (vader86)
Vader, what year and color vette do you drive? I may have seen you around Baton Rouge.
Old Mar 11, 2004 | 02:50 PM
CFI-EFI's Avatar
CFI-EFI
That's too bad. You CAN fix that, you know.
RACE ON!!!
Old Mar 11, 2004 | 04:48 PM
85loub's Avatar
85loub
Thanks for all the help!!!
Old Mar 11, 2004 | 04:52 PM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
I've got a 180 with the fan switch and chip. Keeps me nice and cool. You might also look into getting an oil cooler. Got one on the '89 (factory) and it works great!
Old Mar 11, 2004 | 05:23 PM
QuikZilver's Avatar
QuikZilver
Default Re: 160 degree thermostat (89Corvette6spdFX3)
:cry I need to get my 160 installed ASAP. Dealership put in a 180 the last time I had the waterpump replaced (End of last year). Now with the warmer temps getting closer, I need to get it in to run cooler!! Thanks for reminding me!
:smash:
Old Mar 11, 2004 | 09:56 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
My car came with hypertech chip and 160 stat.
No complaints and it runs cool even when it's 90-100 outside :thumbs:
:cheers:
Old Mar 12, 2004 | 12:32 AM
jfb's Avatar
jfb
A 160 stat will have the same coolant temps at idle as your 180 stat!!!!!
At cruise speed your coolant temp will be lower than with your 180 stat and IC engines shouldn't run 160 at cruise, its too low! Your temps with your 180 stat are normal and not too hot and you will gain nothing with a 160 stat in place.
Old Mar 12, 2004 | 10:23 AM
purplemajesty's Avatar
purplemajesty
I am hoping someone can clarify something for me. Why would the warm up period for a 160 stat be any difference that a 180? Seems to me that since it doesn't actually do anything until you reach the operating temp of that partucular thermostat, the time to reach 160 degress would be the same for both. The difference being the higher rated thermostat keeps going after that.
Also, since a car doesn't actually run at the temp rating of the stat, that is just where it starts to open, why would it cause extra engine wear? I had a 180 stat and ran 201 degress consistently. Now that I have a 160 stat and a chip programmed to turn the fans on earlier, I run 184 degrees but I didn't notice it taking any longer to get to 180. Isn't this hot enough to burn off any moisture?
Thanks for any info you guys may have!
Old Mar 12, 2004 | 10:50 AM
SHINOBI-X's Avatar
SHINOBI-X
Default Re: 160 degree thermostat (purplemajesty)
purplem. a 160 isnt' that bad but when u start removing a thermostat then i'd start to worry.(unless your trying to get throught the desert with a cooling problem then i understand!) but due to the low low temp,the oil (almost)never breaks down enough to give your engine the protection it needs against wear and tear.for it to break down at that temp u'd need to drive it quite a bit around for it to do its job properly. when the engine runs hotter its better for fuel efficency. if your a town daily driver type of guy then i'd say no,go with a 180.but...your saying the 180 runs at 200? my 160 stat when i had it ran around 165-170 in traffic all day with my chip and fans programed. strange....thats just too low for these cars and most others aswell unless your in a some HOT areas! i would say runnin at 185ish is a good temp for your car Purplem. thats my current temp im running NOW,before was too low,it runs much better on emissons and its better on gas and response being hotter aslo.
Old Mar 12, 2004 | 11:23 AM
CFI-EFI's Avatar
CFI-EFI
I am hoping someone can clarify something for me. Why would the warm up period for a 160 stat be any difference that a 180? !
Because, 160 isn't "warmed up". YES! Both thermostats heat the engine to 160, the same. When the cooler stat opens, coolant as allowed to flow through the radiator. This prolongs the engine reaching it's eventual operating temp.
I had a 180 stat and ran 201 degress consistently. Now that I have a 160 stat and a chip programmed to turn the fans on earlier, I run 184 degrees but I didn't notice it taking any longer to get to 180. Isn't this hot enough to burn off any moisture? !
That sounds like a solution, looking for a problem. All your stat change did was increase your warm up time, whether you noticed it or not. Either way your engine is running hotter than the original 180* stat. Your "201 degress consistently" was great. This change sound like a "fix" for what wasn't broke.
An operating temp of 184, will burn off acids and condensation, eventually. The lower the operating temp, the longer it will take. On short hops, it'll never get burned off regardless of the thermostat. Right, wrong, or indifferent, the main thing is if you're happy.
RACE ON!!!
[Modified by CFI-EFI, 9:27 AM 3/12/2004]
To 160 degree thermostat
