Oil pressure problems
Old Mar 11, 2004 | 11:41 AM
Fartleker's Avatar
Fartleker
Default Oil pressure problems
About 8 months ago, I posted a question very similar to this one. After taking it to the mechanic, things seemed to be fixed. But I'm not so sure right now.
Anyways, here's the deal:
My oil pressure sucks. I just changed my oil to 10w30, and at idle, when the car is all warmed up, the pressure is around 10 or 11 psi. Once the car gets moving, this jumps to near normal levels (around 30 cruising).
Around 8 months ago, I got a new oil pump and it seemed to fix things. The oil pressure was hitting as low as 3 or 4 psi.
Should I be concerned that my engine is about to fail? Is it time to save up some money to get ready for a rebuild? Or would putting some thicker oil in there simply do the trick? :confused:
Old Mar 11, 2004 | 01:47 PM
vader86's Avatar
vader86
Default Re: Oil pressure problems (UA89Vette)
If the sender is fine, then either that pump is bad (unlikely with Mellings) or your bearings are about done.
Old Mar 11, 2004 | 01:50 PM
JAKE's Avatar
JAKE
I'll bet that the pressure is fine until the oil temperature climbs above 200 degrees F, then it begins to fall below 20 psi at idle; the hotter it gets the lower the pressure at idle too.
Oil temperature, oil weight and bearing clearances are all playing a part in the low pressure readings at idle.
Without rebuilding the engine and/or installing a better oil cooler, the simple fix is to switch to Mobile 1 15W50, Valvoline VR1 20W50 racing oil, or Pennzoil GT 20W50.
Don't get locked in on the factory recommended oil weight. The correct oil weight for your specific engine depends on several variables; just choose the weight that works for YOU.
Jake
[Modified by JAKE, 12:51 PM 3/11/2004]
Old Mar 11, 2004 | 03:15 PM
Fartleker's Avatar
Fartleker
Default Re: Oil pressure problems (vader86)
The mechanic said that he checked one of the bearings and said that it was fine. Also, the pump was just replaced 8 months ago or so, as was the sender.
Old Mar 11, 2004 | 03:17 PM
Fartleker's Avatar
Fartleker
Default Re: Oil pressure problems (JAKE)
Jake
The pressure actually drops below 20 around 170 or so (will double check that this afternoon). I typically don't drive far enough to let the oil temp get much above 205 or so, so I have no idea how far it would drop.
I'll change out the oil next time to one of the one's that you recommended. Hopefully it'll help.
Any other ideas of what I should do?
Old Mar 11, 2004 | 03:30 PM
frank j. moran's Avatar
frank j. moran
how many miles on this unit, from your description I suspect you have too much bearing clearance, prob worn out.
Old Mar 11, 2004 | 03:33 PM
Fartleker's Avatar
Fartleker
Default Re: Oil pressure problems (frank j. moran)
72k miles on the engine total, on the oil pump, maybe 4k or so.
[Modified by UA89Vette, 12:33 PM 3/11/2004]
Old Mar 11, 2004 | 04:33 PM
frank j. moran
your orig post indicated 3-4 lbs. which is not good, if you have 11 lbs after it is real hot, after a long drive then I would not be too concerned. Letting it idle up to temp is not a real good indicator unless you let it run a long time. pressure problems from bearing wear/clearence usually surface after a road drive and you come to a stop in gear (AT) the light or guage flicker or the pressure is real low on a gage. Pressure is derived from resistance to flow, the resistance is the bearing clearance usually around .0008-.0025in. Did you check any of your readings with a good mechanical gauge? engine idle speed correct, eng temp in limits?? correct sending unit?? , your mileage is good and bearing wear should not be evident unless it was abused or lack of oil changes etc. the higher viscosity oils will mask the problem but you need to continue your diagnosis...I had one with 11 lbs and it was fine. I know how you feel
Old Mar 11, 2004 | 05:00 PM
darkman5001's Avatar
darkman5001
:iagree:
I would also hook up a oil pressure gauge kit directly to the motor after a good drive, and messure it with a diagnostics gauge. Verify that the sender is working and reading properly. You could always have a malfuntioning sender, regarless of how new it is. Once you verify the pressure really is at a dangerous low, then go from there. Do not sit on this though. do something as soon as possible to avoid any further damage. Just my .02.
:cheers:
Old Mar 12, 2004 | 12:09 PM
gcrouse's Avatar
gcrouse
Default Re: Oil pressure problems (darkman5001)
First check the senders, etc as suggested. Then consider:
10w30 is made from a 10w base; extremely light. Try 20w50 as that's a 20w base.
Or since you're in AZ, nothing wrong with straight 30w either.
Old Mar 12, 2004 | 01:07 PM
Unriced's Avatar
Unriced
I agree with Frank...
My 85 runs 12-15 psi at operating temp (540 rpms idle)
Jumps right up 40 when I hit the gas... 50's when cold.
You might want to listen to your motor under hard accelaration
and make sure you dont hear anything bearing related. If those
bearings are suspect, you'll hear them..definitely.. Barring that,
Just go with it.
Old Mar 12, 2004 | 06:19 PM
JAKE's Avatar
JAKE
Default Re: Oil pressure problems (Unriced)
The second of the two numbers, in your case the "30", is the cause of low readings at idle (if the gauge is fairly accurate).
It indicates the resistance to flow at 212 degrees F, which I believe is the temps call for by the SAE.
The first number, in your case "10" indicates the oil's resistance to flow at 32 degrees F.
Try this. Let the car sit overnight. Next day fire it up, place the trans in gear (auto) and note the oil pressure right away.
Now let the engine idle until the oil temp starts coming up. Again put the trans in gear and note the oil pressure at idle.
I'll bet it'll be lower and the hotter the oil gets, the lower the idle in gear reading will be.
Now drain the 10W30 and pour in 20W50 or 15W50 Mobil 1. Do the same test and you'll see the idle, in gear oil pressure will be higher than with the 10W30 gave under the same conditions.
The second number - 50 - will not thin as much as the oil temps climb, so the resistance to flow will be greater and the psi reading will be higher.
Ballpark, you'll want 20 psi idle in gear with oil at 200/210 F.
Jake
[Modified by JAKE, 5:30 PM 3/12/2004]
Old Mar 12, 2004 | 09:52 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
:confused: My L98 makes about 55-60 psi at hot idle... hits 80 regularly. I'd be glad to give you some of my oil pressure...
I guess every motor is different, but 10psi is too low... i'd hook up a mechanical guage to it....
Also, pull out the fitting that feeds to your sending unit, and make sure it's not clogged.
Old Mar 13, 2004 | 03:37 AM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default Re: Oil pressure problems (CentralCoaster)
my 89 had low oil pressure about like you are seeing. The motor is about all torn apart now as I think I have spun bearing. Heads are off now and I can't believe how clean this engine is. I will be pulling the pan today and checking for a spun bearing. I really suggest you pull all the rod and mains before you have a blown engine like I have now.
Old Mar 13, 2004 | 09:26 AM
Motorworx's Avatar
Motorworx
Same here.
Old Mar 13, 2004 | 09:12 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
What is the ideal pressure the oil should be?
Old Mar 13, 2004 | 11:11 PM
Pete K's Avatar
Pete K
Default Re: Oil pressure problems (ir0nmaiden420)
A general rule of thumb is 10 lbs per 1000 rpm.
To Oil pressure problems
Old Mar 14, 2004 | 12:57 AM
JAKE's Avatar
JAKE
Default Re: Oil pressure problems (Motorworx)
Same here.
Chances are the pressure is a lot higher than 80 psi then, especially since you said you have 55-60 at hot idle. 80 is only as high as the gauge reads.
You're either using heavy oil or have tight bearing clearances or a combination of both.
When you said ". . .hot idle. . ." what temp (F.) are we talking about?
Jake
Old Mar 14, 2004 | 02:24 AM
Southern Comfort's Avatar
Southern Comfort
Just go with it.
Now my85 idles around 25-35 warm and cruising at about 50-55psi, and up to 65 on hard acceleration. I just wonder whether I am too high because of a faulty reading. or maybe you are too low for the same reason... :confused:
[Modified by Southern Comfort, 11:24 PM 3/13/2004]
Old Mar 14, 2004 | 07:12 AM
86PACER's Avatar
86PACER
Default Re: Oil pressure problems (Southern Comfort)
:lurk:
