Thin Head Gaskets?
Old Mar 11, 2004 | 01:14 PM
Da Wiz's Avatar
Da Wiz
Default Thin Head Gaskets?
Used to be an old trick for bumping up compression a small amount. Since I am doing some head work, does anyone have a recommendation for which one to use?
Thanks for your assistance...
Thanks CFI. I left out some pretty significant info. The car is a 94 LT1. the heads have never been off, so I expect the stock gaskets were used. I also expect the deck height is unchanged.
:cheers:
[Modified by Da Wiz, 6:27 PM 3/11/2004]
Old Mar 11, 2004 | 01:18 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Thin Head Gaskets? (Da Wiz)
I doubt you'll ever notice a difference from the gasket. How thick was the old one? What engine? Have you messed with the deck height?
RACE ON!!!
Old Mar 11, 2004 | 02:27 PM
93 ragtop's Avatar
93 ragtop
Default Re: Thin Head Gaskets? (CFI-EFI)
I believe the factory gasket is a .049 and impalla head gaskets are .029. That is what I used. Now I was told that for every .0065 you reduce by equals .1 compression ratio. This is all rough math, but I believe the impalla gaskets raise the compression by about .3 ie from 10.4 to 10.7
Old Mar 11, 2004 | 02:36 PM
Da Wiz's Avatar
Da Wiz
Default Re: Thin Head Gaskets? (93 ragtop)
Thanks Ragtop. I will check on them. Direct fit, right?
:cheers:
Old Mar 11, 2004 | 03:45 PM
STL94LT1's Avatar
STL94LT1
I used these, 94/95 Imp SS head gasket part # 12553160
Old Mar 11, 2004 | 06:32 PM
Da Wiz's Avatar
Da Wiz
Default Re: Thin Head Gaskets? (STL94LT1)
Looks like the Impala head gaskets are the way to go. Thanks a ton. Was there anything you guys noticed that you could attribute to the head gaskets?
Thanks fellas. It sure is good to have the benefit of so much experience.
:cheers: :cool: :flag
Old Mar 11, 2004 | 07:36 PM
kman0066's Avatar
kman0066
I got the Impala head gaskets as well and one thing I noticed about them is that they don't extend out and have holes for the pushrods. I had forgotten about this after I put my motor together and was curious as to why one is that way and the other not. Were they just supposed to be like pushrod guideplates?
Old Mar 12, 2004 | 06:03 AM
93 ragtop's Avatar
93 ragtop
Default Re: Thin Head Gaskets? (kman0066)
The thing about not having the guide holes was the only difference I noticed. One thing that came into play on mine, shouldnt be a issue for you, is I had to get my intake milled due to the fact that I had the heads shaved .030 as well.
To Thin Head Gaskets?
