Head Bolt Washers?
Old Mar 12, 2004 | 12:20 PM
Powerdrive's Avatar
Powerdrive
Default Head Bolt Washers?
Bought Fel Pro head bolt kit for my 92 (lt1, alnm heads)My old bolts have washers on them....Fel Pros do not...Do I need washers with aluminum heads?..Even the little diagrams in the helms look like they show washers :confused: All I wanna do is drive it :banghead: :cry Where can I get head bolts with the washers?
Old Mar 12, 2004 | 02:50 PM
JAKE's Avatar
JAKE
Default Re: Head Bolt Washers? (Powerdrive)
Yes, you need washers under the heads of the head bolts. Without the washers, the bolt's head will cut into the aluminum causing uneven loading of the bolt torque.
I'm guessing that you ordered the wrong head bolt kit, you must have gotten a set for an iron head engine.
ARP, SPS, Moroso, and many other sells head bolt sets which come with the required washers. The washers should have a flat side and a beveled side; the flat side goes against the head.
Hope this helps.
Jake
Old Mar 12, 2004 | 02:56 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Head Bolt Washers? (JAKE)
If the new bolts are the right length and otherwise correct, can't he just reuse the old washers? I was going to mention this earlier, but I'm not that familiar with the LT series engines.
RACE ON!!!
Old Mar 12, 2004 | 05:39 PM
JAKE's Avatar
JAKE
Default Re: Head Bolt Washers? (CFI-EFI)
RACE ON!!!
Maybe yes and maybe no. Depends on the size of the head on the bolts (the underside) and how well the washers he has index with the new bolts' underside.
Jake
Old Mar 12, 2004 | 05:54 PM
Powerdrive's Avatar
Powerdrive
Thnx..I was thinking the bolts would cut into the heads also....The local parts guy double checked the Fel Pro prt# and called one of the Chevy dealers parts dept. According to the parts guy at Chevy...."only Zr1s had washers..." :skep: :bs :confused: Ever had the feeling youre surrounded by idiots. Thanks again CF kix azz.... :chevy (no the old washers are sized to the bolt ...They slide.... they spin ...but they dont come off :nonod: )
[Modified by Powerdrive, 5:02 PM 3/12/2004]
Old Mar 12, 2004 | 06:40 PM
CFI-EFI's Avatar
CFI-EFI
I was afraid they might not be removable, that's why I kept silent. My 1984 - 1989 Corvette parts book doesn't show head bolt washers for anything. Do the aluminum headed L98s have a washer faced bolt? *I* sure wouldn't want to bolt down an aluminum head without washers.
RACE ON!!!
[Modified by CFI-EFI, 4:44 PM 3/12/2004]
Old Mar 12, 2004 | 07:48 PM
JackDidley's Avatar
JackDidley
CFI-EFI, my 87 has headbolt washers stock. The i.d. is smaller than the threads, so it stays put. :chevy
Old Mar 12, 2004 | 07:57 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Head Bolt Washers? (Spankyellow)
THAT'S why I can't find washers in my parts book.
Thank you.
RACE ON!!!
Old Mar 12, 2004 | 10:27 PM
96GS#007's Avatar
96GS#007
FWIW I just did my heads on my LT4 about 6 weeks ago. The original bolts did not have washers under them. My new ARP head bolts have washers and of course I did use them :)
Old Mar 12, 2004 | 11:51 PM
Powerdrive's Avatar
Powerdrive
Default Re: Head Bolt Washers? (96GS#007)
:D Well at least I know the poor SOB wasnt lyin to me :jester Ill feel better with the washers :chevy
Old Mar 12, 2004 | 11:59 PM
kman0066's Avatar
kman0066
Steel bolts---aluminum heads=corrosion.
Steel bolts---iron heads=fine.
You need the washers. :) Any time you are joing 2 different metals.
The coating on the bolts would usually protect, but when the metal contacts and spins, this coating will get rubbed off. The solution, aluminum washers. This minimizes the corrosion levels which still exists but it's only washers and bolts rather than the heads themselves.
Old Mar 13, 2004 | 08:20 PM
JAKE's Avatar
JAKE
Default Re: Head Bolt Washers? (kman0066)
I had to replace a head bolt when I re-built a 355 a few years ago so I went to Chevy for a single replacement. It came with an intergral washer to the bolt head. No, not one that is in addition to the bolt, but part of the bolt itself.
I questioned it at the parts counter since it was different from the other head bolts I had and I was shown on their computer screen that it's the correct replacement head bolt.
I do know that some aftermarket head bolt companies - Milidon comes to mind - call for ordering a washer package when you get their head bolts. the bolts and washers are sold separately, but the ARPs I'm running came with washer.
A guy I know installed a new pair of AFR 210s without using washers under the heads of the head bolts and you should see the mess they made of the heads. The car owner needed to send the heads back to AFR to have the head bolt seats repaired.
Jake
To Head Bolt Washers?
