Engine surges at idle
Old Mar 13, 2004 | 07:01 PM
rebuild's Avatar
rebuild
Default Engine surges at idle
I have a '93 w/auto at idle theengine revs onits own. Anyone know what could cause this?
Old Mar 13, 2004 | 07:19 PM
madquake's Avatar
madquake
Default Re: Engine surges at idle (rebuild)
look into the distributor Opti Spark .
Seems like you are a bit new to the forum ... Whatever you do ...Do not hose your engine down!!
Good luck ...
Mark A.
Old Mar 13, 2004 | 07:20 PM
JAKE's Avatar
JAKE
Are you getting any code(s);There are a number of things that could cause it. Here's a partial list:
Defective/malfunctioning
Sensor(s),
Injector(s),
Ignition timing
Fuel pressure/regulator
Vacuum leak,
Can you give any more details on what's happening?
Jake
Old Mar 13, 2004 | 07:38 PM
1990CORVETTE's Avatar
1990CORVETTE
isnt this in C4 general
Old Mar 13, 2004 | 07:45 PM
rebuild's Avatar
rebuild
Default Re: Engine surges at idle (1990CORVETTE)
No codes while idling engine revs up maybe 300 rpms and drops back down, usually after its warm it probably does it cruising too but isn't as noticable. Sometimes if i gun it the car will hesitate a bit don't know if thats related.
Old Mar 13, 2004 | 10:12 PM
Dilligas's Avatar
Dilligas
I had the same symptoms and it ended up being my opti. Idle would surge while I was stopped and occasionaly stuuter as I took off. With mine it ran fine in the upper RPM's.
Old Mar 14, 2004 | 01:08 PM
ROME's Avatar
ROME
Clean or replace the idle air control valve (IAC) on your throttle body. Also, with your engine turned off, make sure your throttle blades are completely closed when the throttle is not depressed. Otherwise your IAC will continue adjusting itself back & forth trying to solve the problem.
A bad IAC valve was causing my car to surge up & down about 500 rpm (more or less). Took me a while to figure out the problem.
Old Mar 14, 2004 | 01:16 PM
bogus's Avatar
bogus
it's the opti. A sure sign that the cap/rotor assembly are badly carbon traced.
what happens is that at idle, a miss occurs. the engine computer manipulates timing, mixture and idle to make a fix, but then the engine runs ok, the computer resets to expected norms... and this game goes on.
annoying as hell....
it is not cost effective to replace just the cap and rotor. it requires the same amount of labour, so all you are saving is 200.00, and, costing, the need to do it again in a few short months.
replace the entire assembly.
also, there are options available now to replace the opti... or, at least get rid of the high voltage side - LTCC & Del-Teq have come up with coil systems that replace the high voltage. I have installed the LTCC and LOVE IT!
Dyna-Tech Engineering has redesigned the optispark unit.
take your pick.
keep us posted.
Old Mar 14, 2004 | 04:22 PM
madquake's Avatar
madquake
Default Re: Engine surges at idle (Dilligas)
Is it me or do I see a trend of the Opti going out in all kinds of different fashion??
Everytime I talk to someone or hear about the opti I get a different symptom on how it went out... making it pretty frustrating to pinpoint.
Just an observation ....
PS Dilligas Love your Aqua Colored C4 ... I have an Aqua roadster and sometimes I wish it was either a coupe or it had a Hardtop!!
I'll leave my sig so ya can peep it!!
Mark A.
Old Mar 14, 2004 | 05:39 PM
Dilligas's Avatar
Dilligas
Default Re: Engine surges at idle (madquake)
Mark A.
Thanks, after riding in Preachers car today with the top down I have a serious case of vert fever. The white top on your Aqua looks awesome :thumbs: :thumbs:
To Engine surges at idle
