Anyone cleaned their EGR?
Old Mar 12, 2004 | 12:34 PM
jmrl98's Avatar
jmrl98
Default Anyone cleaned their EGR?
I'd like to take it off & clean it, but worried some parts (the valve mainly)may be damaged by the type of cleaner used. Also, did you clean out the port into the manifold? TIA, :seeya
Old Mar 12, 2004 | 12:56 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: Anyone cleaned their EGR? (jmrl98)
I cleaned my EGR straight outta my engine compartment. :lol:
Old Mar 12, 2004 | 01:07 PM
jmrl98's Avatar
jmrl98
Default Re: Anyone cleaned their EGR? (VictorRussell'92)
Yeah, the thought is crossing my mind!! :lol:
Old Mar 12, 2004 | 05:06 PM
1996man's Avatar
1996man
im considering it
Old Mar 12, 2004 | 07:12 PM
GS057's Avatar
GS057
2018 C6 of Year Finalist
:withstupid:
Old Mar 12, 2004 | 07:44 PM
1990CORVETTE's Avatar
1990CORVETTE
:lol: :lol: :lol: :lol: :lol: :lol:
How did you do this,,, and why :lurk: :lurk:
Old Mar 12, 2004 | 09:27 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Anyone cleaned their EGR? (GS057)
:withstupid:
:withstupid: :D
Sure cleans up the engine compartment and makes valve cover removal a whole lot easier :D
:cheers:
Old Mar 13, 2004 | 10:36 AM
madmike's Avatar
madmike
Default Re: Anyone cleaned their EGR? (AGENT 86)
how did you clean your egr outa your engine compartment. You mean you took it off your engine?. This one went over my head. :confused: When I cleaned the plenum, I took mine off and hosed it out with throttle body cleaner, made sure the diaphram wasnt torn and put it back..... :hurray:
Old Mar 13, 2004 | 09:07 PM
AGENT 86's Avatar
AGENT 86
Default Re: Anyone cleaned their EGR? (madmike)
:yesnod: :yesnod:
Removed it and installed block off plates for egr and diaphram, and welded shut the hole in the exhaust.
:cheers:
Old Mar 13, 2004 | 09:44 PM
wake's Avatar
wake
Default Re: Anyone cleaned their EGR? (1996man)
im considering it
Uh, you don't have one on the LT4... :confused:
I cleaned mine on the LT1 car I had before... I just used a vacuum pump to hold the valve open and carb cleaner...
Old Mar 13, 2004 | 11:26 PM
madmike's Avatar
madmike
Default Re: Anyone cleaned their EGR? (wake)
Oh i see. The problem with doing that in cali is when you smog the car the Nox is too high. You need that extra little exhaust to bring it town. what i do is cut the head off a 1/8 inch bolt and place the bolt between the egr solenoid and the Egr vaccum diaphrams. When the solenoid opens the vaccum, it just sucks on the bolt. It looks pretty good too, you cant tell the rod is in the vaccum hose line. When its time to smog, just cut a piece of ball point pen tube and place where the rod is. Please dont tell the smog police. By the way, you have to retrofit the hose to the diaphram with a longer hose. It makes it easier to unplug and cap. Or you can cap at the throttle body as long as that diaphram doesnt open. I live dangerously dont I? :rofl: :hurray:
Old Mar 13, 2004 | 11:34 PM
XQIZT's Avatar
XQIZT
i was getting the EGR code at highway speeds. during an engine rebuild, i just flexed the valve a few times...since then i haven't had a problem...(with the EGR, anyway) :crazy:
Old Mar 14, 2004 | 04:03 AM
1996man's Avatar
1996man
Default Re: Anyone cleaned their EGR? (Orlando85UCFvette)
are you positive i dont have EGR? because i see what looks exactly like EGR on the earlier LT1s
Old Mar 14, 2004 | 05:53 PM
mjfox's Avatar
mjfox
I had that code come up I replaced the egr and solenoid not very expensive mys well replace while you have it out
mike
To Anyone cleaned their EGR?
