Torque Convertor or Trans problem maybe
Old Mar 14, 2004 | 08:08 PM
pipe's Avatar
pipe
Default Torque Convertor or Trans problem maybe
I recently had my trans done in my 90 coupe. The mechanic said he put in a 2000 stall spd. convertor and reprogrammed the shift points in it. I bracket race the car also. My question is that when I come off the line and have my foot down to the floor when it's ready to shift into the next gear the engine revs up to 6,000rpm I back out of it cause it revs so high I've never driven a car with a stall convertor in it. Is this normal for it to rev so high between shifts it does not do it from the 2nd to 3rd shift? THANKS FOR ALL THE ADVICE :confused:
Old Mar 14, 2004 | 08:11 PM
vader86's Avatar
vader86
Default Re: Torque Convertor or Trans problem maybe (pipe)
thats not caused by the TC, sounds like your mechanic played with the TV cable and/or the tranny internals
Old Mar 14, 2004 | 08:33 PM
CFI-EFI's Avatar
CFI-EFI
This is totally, non converter related. There is something wrong, internally, with the trans. Get it back for warranty repair, ASAP. Good luck, and...
RACE ON!!!
Old Mar 14, 2004 | 10:46 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
6k rpm's w/o upshifting seems awfully high even w/ the TV cable set at the highest position but I guess it's possible. I've set mine to the highest (slider pushed all the way in) and saw a max of 5800 and it did upshift. I noticed also that the 5800 was only in 1st gear, all the other gears shifted at 54-55K rpm's. Push the adjust tab (shaped like a D ) and pull the slider out toward the front of the car a little bit. That will make it shift sooner, or you could adjust it the proper way. That way is:
1) press the "D" tab and push the slider all the way in "toward the rear" ( by reading the problem you have I assume it's already there)
2) press the gas pedal and it will ratchet itself to the proper position.
If the slider is already out some, I'd take it back to the trans guy and ask what's up.
Old Mar 15, 2004 | 07:35 PM
pipe's Avatar
pipe
Default Re: Torque Convertor or Trans problem maybe (War Machine)
I called the guy who did my trans today and told him what happened he told me to bring it in to his shop. He said the govenor springs need to be readjusted and he will check out everything else. WHEW SOUNDS GOOD TO ME :thumbs:
To Torque Convertor or Trans problem maybe
