ZF6 Tranny Noise
Old Mar 14, 2004 | 11:02 PM
Pappa_Bear's Avatar
Pappa_Bear
Default ZF6 Tranny Noise
Without bastardized chb88's thread any further, I'm starting a new thread on this. Here's the ticket:
Bought this Vette at a REALLY good price and one of the things I noticed right off was clutch wear. Ordered a new RAM clutch, pressure plate, throughout bearing and pilot bushing from Summit. Clutch is super smooth and grabs well. The problem I'm having is that I'm hearing a loud noise when decelerating. If I push the cluch in, the noise virtually goes away. Doesn't make any noise while in neutral and stopped. So......sounds like througout bearing banging around. This is the first time me and my boys have dealt with a ZF6 so when we noticed the setup push/pull we were amazed, and yet entriqued. I I followed the manual on removing the bellhousing; remove ball stud screw lock, screw in ball stud screw to release fork, turn housing/fork assembly countercockwise to release fork from bearing...yadda yadda. When putting it back together, the manual I was reading didn't mention anything of what to do with the now sunken in ball stud screw on the fork, so I backed it back out flush with the bell housing like it originally was. Looking at my shop manual (which I left home :banghead: ) I read that the screw was to be torque to 30 lbs. Which I don't get. If you back it out until it's flushed, why the torque spec. Which got me to thinking, was I supposed to flush it, then turn it in to 30 ft/lbs? Since we're hearing this noise, we'll have to go back in and do something...but I'd like to know what to do before doing it....Get it? :nopity
[Modified by Pappa_Bear, 10:03 PM 3/14/2004]
Old Mar 14, 2004 | 11:11 PM
kman0066's Avatar
kman0066
Default Re: ZF6 Tranny Noise (Pappa_Bear)
If you turn it out, will it not torque? I show 33 ft lbs in my book(Chiltons)
Next time, don't bother with this stud, you can pull the fork back without touching the ball stud.
Old Mar 14, 2004 | 11:29 PM
Pappa_Bear's Avatar
Pappa_Bear
Default Re: ZF6 Tranny Noise (kman0066)
Thirty-three. Yes that's right. So basically I did do the right thing by backing it back out flush and installed the lock. Good....now why is my throughout bearing making all this noise...assuming it's that. Thanks!
Old Mar 15, 2004 | 07:37 AM
Atok's Avatar
Atok
:iagree:
My ball stud was tightened to 30+ ft-lbs then the lock goes on. Sometimes you need to remove the stud. If the clutch is worn badly you will not be able to slide the clutch forks back off the stud. That was the problem I had.
Old Mar 15, 2004 | 10:29 AM
Flareside's Avatar
Flareside
Did you check the throwout bearing fit on the output shaft? The later clutches used a larger throwout that would fit loosely over the early ZF6 output collar. I could see that causing a noise. You may have the wrong throwout bearing.
[Modified by Flareside, 10:29 AM 3/15/2004]
Old Mar 15, 2004 | 08:23 PM
Pappa_Bear's Avatar
Pappa_Bear
Default Re: ZF6 Tranny Noise (Flareside)
Thanks for the idea Flareside. I have something to look at now. I'll get in touch with Summit to see what was sent exactly. I'll be tearing up the twisties in Arkansas this weekend on the crotch-rocket this weekend, so I may take a couple.
To ZF6 Tranny Noise
