rear end noise... crap
Old Mar 15, 2004 | 09:22 AM
Z06_BluByU's Avatar
Z06_BluByU
Default rear end noise... crap
I recently installed some new bearings in the rear end.. I followed the assembly manual, using the factory shims in the correct places and torqued everything down as specified.. the car makes no noise while accelerating or going slowly.. or while decellerating.. however, I noticed a high pitch sound while going about 45 mph and higher and a constant speed... its like the sound that is produced when you run your finger around the rim of a crystal glass.. a high pitch hum...
if I push the clutch pedal in at that time it instantly goes away.. I think its related to the rear end since I just installed the new gears but I can verify the sound is comming from there..
any ideas? This is a bit frustrating..
thanks!
Old Mar 15, 2004 | 10:20 AM
sothpaw2's Avatar
sothpaw2
Default Re: rear end noise... crap (BluByU)
I have the same or a similar problem. I was told once by a mechanic it was the diff but I am hoping something easier to fix.
Old Mar 16, 2004 | 08:31 AM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: rear end noise... crap (sothpaw2)
ttt
Old Mar 16, 2004 | 09:59 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
ouchy :lurk:
To rear end noise... crap
