"Service ASR"
Old Mar 16, 2004 | 11:52 AM
94 M-6's Avatar
94 M-6
Default "Service ASR"
heres the dilly
the light comes on, and the asr doenst work. Fine, but sometimes i start the car, it works for a few minutes, and i test it to make sure it work, and the system works good, but then the light comes on, and its done again, any thoughts on this would be great...
thx
Old Mar 16, 2004 | 12:47 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: "Service ASR" (94 M-6)
I know this sounds crazy but it might be the TPS. Have you adjusted it? Messed with the throttle body latley?
Old Mar 16, 2004 | 02:43 PM
69mako's Avatar
69mako
Default Re: "Service ASR" (VictorRussell'92)
My 94 did that 2 years ago..it was a sticking switch in the brake master cyl....tap it a few times with a hammer...don't smash it....and it should be OK then....also try bleeding your system and putting new fluid in...
hope this helps :yesnod: Larry :steering:
[Modified by 69mako, 2:11 PM 3/16/2004]
Old Mar 16, 2004 | 03:08 PM
kittmaster's Avatar
kittmaster
Get the codes out of the CCM and report back
Old Mar 16, 2004 | 03:52 PM
94 M-6's Avatar
94 M-6
Default Re: "Service ASR" (kittmaster)
thx for the replys, I havent done anything with the TPS/TB at all, other than clean the IAC. I just had new fluid put in the car, as I had to change the slave cyl, maybe it wasnt blead properly. I havent tapped it with a hammer either. Also, Im not sure how to get the codes, so if you have a link or directons, that would be great. thanks again.
Paul
Old Mar 16, 2004 | 04:58 PM
rick lambert's Avatar
rick lambert
Here's your link.www.c4vettes.com/ecm.htm, good luck, let us know. :rolleyes:
Old Mar 16, 2004 | 08:15 PM
CorvetteClug's Avatar
CorvetteClug
Default Re: "Service ASR" (rick lambert)
Could be a wacky speed sensor. Happened in my car. :smash:
To "Service ASR"
