I have a loose caliper! Help!
Old Mar 17, 2004 | 06:19 PM
Bat Man's Avatar
Bat Man
Default I have a loose caliper! Help!
Urgh, when I take my car out of gear and just coast, especially at slow speeds, I can hear this clanking noise coming from the right driver side wheel. At first I thought it was the wheel bearing, but I took my wheel off and started testing and fooling around. I noticed my caliper, it is moving around about 1/8th to 1/4ths an inch causing the noise.
The two caliper bolts seemed pretty tight, the wheel is pushed back as far as I could get it, and the lug nuts are tight.
What could cause it? I noticed the other side is a little loose, but nothing like this.
[Modified by Valleybacker, 6:20 PM 3/17/2004]
Old Mar 17, 2004 | 06:28 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: I have a loose caliper! Help! (Valleybacker)
If the caliper is moving on it's mount either the bolts are loose, the bolts are worn or the bolt holes in the caliper are worn.
You can get new bolts & washers at a local Chevy dealer; these should be replaced when changing calipers or rotors.
Old Mar 17, 2004 | 06:29 PM
Bat Man's Avatar
Bat Man
Default Re: I have a loose caliper! Help! (65Z01)
We didn't replace the caliper or rotors, we changed the pads.
So the two bolts need replaced along with the pin?
Old Mar 17, 2004 | 06:49 PM
ittlfly's Avatar
ittlfly
Did you check the locking ring that holds the pin in place? It's possible the pin is backing out allowing the caliper to move within the mounting bracket. Just a thought.
Old Mar 17, 2004 | 08:20 PM
JasonL's Avatar
JasonL
You didn't specify front or rear, but I'm assuming this is the front.
Since you just swapped pads, you may have forgotten the anti-rattle clips. This will cause clanking around until you apply the brakes.
http://home.earthlink.net/~olylt1/An...tle_clips.html
Old Mar 17, 2004 | 08:46 PM
Bat Man's Avatar
Bat Man
Default Re: I have a loose caliper! Help! (JasonL)
I thought my brake pads came with anti rattle clips built in.
:confused:
Old Mar 17, 2004 | 09:05 PM
shotchkiss's Avatar
shotchkiss
I'm curious what the fix for this is also, both of my front calipers rattle around even though the pads are tight, I thought it was normal, guess it isn't?
Old Mar 17, 2004 | 09:11 PM
Bat Man's Avatar
Bat Man
Default Re: I have a loose caliper! Help! (shotchkiss)
I don't remember them making this noise until I changed the pads.
So no way its normal. And it definatly goes away when i apply the brakes.
Old Mar 17, 2004 | 09:22 PM
JasonL's Avatar
JasonL
:confused:
Most brands do *not* include the clips. If you don't remember seeing them in the box, chances are you forgot about them. Very common mistake.
Old Mar 17, 2004 | 10:02 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
I'd also look at the caliper mounting bracket, I don't remember if ti is bolted to the car like the front ones are.
Old Mar 18, 2004 | 07:16 AM
Fabinatl's Avatar
Fabinatl
Default Re: I have a loose caliper! Help! (C4DC)
My car (96CE-LT4) was doing this when I bought it a few weeks ago. I took it to a corvette place and they said it was missing the clips on the brake pads / calipers. Of course you can not just buy the clips, you have to buy the "kit". They replaced the "kit" and now there is NO sound. It sure makes a big difference!
To I have a loose caliper! Help!
