My hood stuck closed!
Old Mar 17, 2004 | 10:30 PM
CptMorgan's Avatar
CptMorgan
Default My hood stuck closed!
My hood won't open! :mad
The driver’s side latch isn't releasing. Tried pulling the cables under the dash with a pair of pliers to get more travel without luck. There must be another way to get at the hood latches. Ideas?
[Modified by CptMorgan, 7:31 PM 3/17/2004]
Old Mar 17, 2004 | 10:45 PM
VAHROOM's Avatar
VAHROOM
Default Re: My hood stuck closed! (CptMorgan)
I know Mid America sells a tool that helps with this. After you get it open make sure you attach long wire ties around the latch where the cable attaches. Let them hang into the cowl under the wipers. A simple pull on each wire tie will open the hood if it happens again.
Old Mar 17, 2004 | 10:54 PM
shotchkiss's Avatar
shotchkiss
This may help http://www.corvetteactioncenter.com/...n.php?qstId=87
Old Mar 18, 2004 | 11:43 AM
CptMorgan's Avatar
CptMorgan
Got it open! Thanks guys.
Old Mar 19, 2004 | 10:11 AM
BigC4's Avatar
BigC4
Awesome, I have the same problem. Removed everything from the fire wall to clean up under the hood. After cleaning up shut the hood for the night, later I couldn't get it open.
Old Mar 19, 2004 | 06:54 PM
emoshn's Avatar
emoshn
Default Re: My hood stuck closed! (BigC4)
Mine has threatened to stick a couple times but always eventually worked. I've been detailing the engine bay this winter and was looking at the latch setup. It is adjustable. Anybody done that? Share the knowledge?
Old Mar 20, 2004 | 12:37 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Once you get it open,, try what i did... saves a bunch ...
Old Mar 20, 2004 | 12:55 AM
Vett-eight-nine's Avatar
Vett-eight-nine
Default Re: My hood stuck closed! (vinnies87)
Must be a common occurrence. I just got done dealing with mine and am afraid to shut it again. The source of my problem is a broken release spring.
Anybody have any ideas for a fix for that?
p.s. nice pic, Vinnie :thumbs:
Old Mar 20, 2004 | 08:44 AM
Rich B.'s Avatar
Rich B.
Why not buy the tool from the man who designed it???
http://www.gordonkillebrew.com
$20 and well worth it.
Old Mar 20, 2004 | 11:37 AM
Rich B.'s Avatar
Rich B.
Vinnie87 -
That's an excellent idea which I plan on copying (Thanks!) - where did you get the cable and crimp-ons???
Old Mar 20, 2004 | 11:46 AM
XQIZT's Avatar
XQIZT
first, if it ever gets stuck, try holding the lever inside the car open while lifting the hood (you have to open your drivers window to do this). i had to do this with mine once. after it is open, look at the latch that didn't stick and see how far out the "catch" sticks into the hole...then adjust teh other side. the cable housing is threaded, just loosen the set nut and spin. you'll see the catch moving. if the hood is sticking then obviously the catch needs to be moved further out of the hole....good luck :thumbs:
Old Mar 24, 2004 | 09:54 PM
VAHROOM's Avatar
VAHROOM
Default Re: My hood stuck closed! (Rich B.)
Just use long wire ties. They install in seconds and work great.
Old Mar 24, 2004 | 09:57 PM
Rich B.'s Avatar
Rich B.
Default Re: My hood stuck closed! (VAHROOM)
Would you believe I've never even heard of a "wire tie"??? :crazy:
Old Mar 24, 2004 | 10:10 PM
Vett-eight-nine
Possibly a nylon cable tie?
They would work! :yesnod:
Old Mar 25, 2004 | 06:36 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I greased up my hood latches, and it opens smooth as silk now. I used to be wary that I was gonna break the release lever everytime I pulled it.
Old Mar 25, 2004 | 02:19 PM
SteveBlack90's Avatar
SteveBlack90
Default Re: My hood stuck closed! (CentralCoaster)
What sort of grease did you use? Can I use wheel bearing grease (since I have a lot of it around)?
Old Mar 25, 2004 | 03:28 PM
ittlfly's Avatar
ittlfly
Default Re: My hood stuck closed! (SteveBlack90)
I use a spray can of white lithium grease to keep them lubed up. That's what the Helms suggests to use. :yesnod:
To My hood stuck closed!
