Need 1985 ECM Code 54 help !
Old Mar 18, 2004 | 12:35 PM
Slingshot's Avatar
Slingshot
Default Need 1985 ECM Code 54 help !
I have a 1985 with the CHeck Engine light on.
I have replaced the fuel pump relay switch and the fuel pump. I've checked all the wires and there seems to be good connection.
I'm getting Code 54 ( Fuel Pump Voltage Low Circuit) on the Control Panel.
The light will go off as long as I turn the switch off and then restart the car. The car seems to start and run fine. ...now Just this "CHeck Engine" light is aggravating.
My mechanic says it could be the ECM itself but I wonder about that. He says he can't guarantee that would fix it.
What advice can you guys give??
Should I take it to another mechanic??? Or Leave it alone until something else happens?? The car has 180,000 miles on it but still runs strong.
Thanks in advance.
S
[Modified by Slingshot, 12:36 PM 3/18/2004]
[Modified by Slingshot, 12:37 PM 3/18/2004]
Old Mar 18, 2004 | 01:14 PM
Corvette0096's Avatar
Corvette0096
Default Re: Need 1985 ECM Code 54 help ! (Slingshot)
I would get a new ECM. They are cheap and It's allways nice to have a spare.
http://www.c4vettes.com/ecm.htm
Old Mar 18, 2004 | 02:37 PM
Slingshot's Avatar
Slingshot
Default Re: Need 1985 ECM Code 54 help ! (Corvette0096)
The price I was quoted was $125 and no guarantee that would fix it.
Does that price sound right??
Old Mar 18, 2004 | 02:51 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Does the code come up at startup or after the engine is running?
Does it come up every time or is it intermittent?
[Modified by 65Z01, 2:52 PM 3/18/2004]
Old Mar 18, 2004 | 03:10 PM
Slingshot's Avatar
Slingshot
Default Re: Need 1985 ECM Code 54 help ! (65Z01)
Intermittent.
Check Engine light doesn't come on all the time either.
Mechanic did the scan so I'm not sure when it comes up.
Old Mar 18, 2004 | 03:49 PM
65Z01's Avatar
65Z01
The reason I asked is that the ECM checks voltage at various times;
-during the 2sec fuel rail prime at startup, when the relay supplies power to the fuel pump
-during normal running when only the oil pressure switch supplies power to the fuel pump
If the code is thrown during normal engine operation it's possible that the oil pressure switch is flakey or boarder line.
An intermittent is tough to diagnose, so you might consider replacing that switch before doing the ECM.
To Need 1985 ECM Code 54 help !
