Compression ratio with 64cc heads
Old Mar 19, 2004 | 11:14 AM
dave_85's Avatar
dave_85
Default Compression ratio with 64cc heads
I have a 85 with the one big valve relief on the piston. I am installing
64cc heads and I want to calculate the new compression ratio.
Does anyone know how many cc the valve relief is. One thought was
to use play dough and fill the relief then measure the volume of play
dough.
Old Mar 19, 2004 | 12:52 PM
mike 1985's Avatar
mike 1985
Default Re: Compression ratio with 64cc heads (dave_85)
Stock the 85 is supposed to be 9.75 with a 76CC head, the 64 will put you at 10.25 if i remember correctly. You can look at any SBC piston in summit and see what the comp ratio's are with the 76CC and 64CC heads.
You can switch to a 64 CC head IF IT'S ALUM. If your staying with cast iron you'll probably want to stay with the 76CC head
Old Mar 19, 2004 | 02:31 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Compression ratio with 64cc heads (mike 1985)
mike 1985,
Where are you getting your info? My Corvette parts book shows the 1984 and the 1985, as having the same forged pistons and 76 cc iron heads. Therefore, if he has the factory pistons, he should have the stock 9.0:1 compression ratio. Again, if the pistons are stock, one doesn't need to know the cc's of the valve reliefs. It's just math re figuring with the 64 cc heads. This is IF you trust the factory 9.0:1 rating.
RACE ON!!!
dave_85's Avatar
dave_85
I think I can answer my own question. I found a web site that said the 85 was 9.0:1 with a .021 head gasket. I used the Dyno2000 compression ratio calculator. Choose a flat top piston and play with the Piston Down Bore number to get 9.0:1 with a 76cc head and .021 gasket. Then change the head to 64cc and the gasket to .039 and you get 9.79:1.
Old Mar 19, 2004 | 02:34 PM
dave_85's Avatar
dave_85
CFI-EFI :iagree: you were to quick with your answer.
Old Mar 19, 2004 | 07:47 PM
CFI-EFI's Avatar
CFI-EFI
:thumbs:
RACE ON!!!
Old Mar 20, 2004 | 09:55 AM
opel's Avatar
opel
dave_85, I know you can run 64 cc heads on the 85 with out any problem.
I've been running vortec heads on my 85 for a year now with no problems. I dont hear so well so I would not know if I had knock I just ran high test and had freinds tell me if I had knock.It works great.
I'm in the middle of building a 388 and I'll be running vortec heads on it as well
Dave
:flag
Old Mar 20, 2004 | 09:58 AM
vader86's Avatar
vader86
Default Re: Compression ratio with 64cc heads (CFI-EFI)
They do.
To Compression ratio with 64cc heads
