Wire boot protectors when using headers
Old Mar 19, 2004 | 11:20 AM
geezel's Avatar
geezel
Default Wire boot protectors when using headers
Is it necessary to use spark plug wire boot protectors with long tube headers? Which are the best in appearance, performance and value? Summit offers quite a few options.
Old Mar 19, 2004 | 11:28 AM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Re: Wire boot protectors when using headers (geezel)
As you can see from my sig pic, I'm using DEI boot protectors. They're rated at 1200*F. I've alway had problems burning my boots even with header wrap so protectors seemed like a no brainer especially when spark plug wires are like $60. :crazy:
Old Mar 19, 2004 | 11:33 AM
geezel's Avatar
geezel
Default Re: Wire boot protectors when using headers (NUckINg FuTS)
What loom kits are you using? Will they work with stock center-bolt valve covers?
Old Mar 19, 2004 | 11:40 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
I have used DEI and am currently using Taylor boot covers on my 87. They both work great! I'm using the stock looms except I'm not using the bottom 2-wire looms. As long as they don't touch the headers you'll be fine. I had one that was touching the header and the heat burned through it in about 6 months and it burned the wire. There really is not much difference between the two other than Taylor offers a variety of colors.
Old Mar 19, 2004 | 03:18 PM
NUckINg FuTS
"Made For You" wire looms, part #5035613. I don't know about stock centerbolts, but the ones I'm using required some grinding on the base of the looms to fit correctly :smash:
To Wire boot protectors when using headers
