recommend floor jack that fits under C4 ground effects
Old Mar 19, 2004 | 03:52 PM
LT4DRIVER's Avatar
LT4DRIVER
Default recommend floor jack that fits under C4 ground effects
Can anyone recommend a floor jack that can clear a Greenwood GC3 kit? I have exactly 5 inches to slip through. Thanks. :)
Old Mar 19, 2004 | 05:02 PM
TA's Avatar
TA
Default Re: recommend floor jack that fits under C4 ground effects (LT4DRIVER)
Try driving onto a section of 2 x 10. That'll get you a bit more height.
Old Mar 19, 2004 | 09:41 PM
HWoods's Avatar
HWoods
Default Re: recommend floor jack that fits under C4 ground effects (TA)
I bought an aluminum jack from Sam's and it clears my lowered 86
Old Mar 19, 2004 | 09:46 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
:iagree:
Old Mar 19, 2004 | 10:19 PM
LT4DRIVER's Avatar
LT4DRIVER
Default Re: recommend floor jack that fits under C4 ground effects (Bruthish)
I realize that I can gain a few inches of clearance by driving onto a plank but since I have to buy a jack anyway I figured might as well see if anyone has one that clears the car on it's own. Thanks for the tip though. :cheers:
Old Mar 22, 2004 | 12:38 AM
Midgetfist's Avatar
Midgetfist
Default Re: recommend floor jack that fits under C4 ground effects (ToyC4)
I've got the Craftsman Aluminum. Saddle/Puck height is 3.5 in. Weight is 40 lbs. Price was $161.00. Overall the construction is very solid. Heres a few pics:
:chevy
Old Mar 22, 2004 | 04:31 AM
LT4DRIVER's Avatar
LT4DRIVER
Nobody has a floorjack that fits?????
Old Mar 22, 2004 | 04:55 AM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
There are some nice low profile aluminum ones that are designed for our cars
here's a 3 1/2 inch high race jack for $300 - a little pricey but I've seen them cheaper if you look around you can find them for under $100 -
Here's the link: http://<a href="http://www.suprastor...aflja.html</a>
Old Mar 23, 2004 | 04:19 PM
LT4DRIVER's Avatar
LT4DRIVER
Midgetfist, ToyC4
Thanks. Both jacks are very similar. I think they're probably made by the same manufacturer. Anyway, I'm ordering the craftsman since I have other craftsmen stuff in the garage. Thanks again. :)
Old Mar 23, 2004 | 06:42 PM
Midgetfist's Avatar
Midgetfist
:cool: :cheers:
Old Mar 24, 2004 | 03:50 PM
SuperL98's Avatar
SuperL98
LT4Driver,
I have the same problem.
Bought the light aluminum jack these guy's are showing and it will slide under but hits the bottom of the ground effects on the way up (even with a home made pad extension).
Only solution I've found is to use the stock scissor jack to get up a few inches before sliding the floor jack under.
Also this light weight jack goes up quick, but takes a lot of force on the handle to jack up.
I also build some long wooden 2x12 ramps, that I use most times.
To recommend floor jack that fits under C4 ground effects
